Previous Thread:
http://www.skylinesaustralia.com/forums/topic/392177-wrecking-1995-r33-gtr-midnight-purple-non-v-spec/page-10
..and I still have a ton of parts here!
If it isn't listed below chances are it's there so please PM.
Car is stored outside so I am reluctant to sell glass, doors, boot lid, etc..
Located in Boronia (SE Melbourne) however happy to freight.
Contact via PM.
FOR SALE:
- 215/45R17 87W Toyo Teo Plus Tyres (Brand New - Set of 4) - $400
- GTR Front Pipe - $160
- Front Driveshafts (require driver side inner) - $120 pair
- Original CD Stacker from R33 GTR (with remote & Loom) - $50
- K & N Air Filter Service Kit (1 and a 1/2 kits) - $20
- Speaker Grille's (Hertz, Focal & Response) - $30 the lot
- Rear Reo - $120
- Rear Garnish - $80
- Front Door Trim (Driver) - $120
- Rear 1/4 Door Trims - $80 each
- Rear 1/4 Upper Trims (C-Pillar) - $60 each
- Electric Window Motors - $120 each
- Passanger Electric Window Switch - $50
- Dash - $220
- Centre Console - $120
- Interior Carpet - $120
- Seat Belts - $60 each
- A Pillar Trims - $50 each
- Roof Lining - $120
- Standard upper arms - $160 pair
- Standard uprights - $160 pair
- Front Crossmember - $220
- ABS Unit - $350
- Windscreen Wiper Motor - $80
- Windscreen Wiper Arm Linkages - $80
- Instrument Cluster Surround - $50
- Brake Master Cylinder - $120
SOLD:
Clutch Master Cylinder
Fuel Tank & Pump
Engine & Gearbox
Exhaust
Intercooler & Piping
Airbox
BOV's & Return
PS Pump
A/C Setup
Wheels
Brakes
Brake Air Ducts
Hubs
Struts
Lower & Upper Arms (Front)
Castor Rods
Sway Bars
Rear Driveshafts
Steering Column
Steering Rack
Strut Braces
Tailshaft
Rear Subframe
Underbody Bracing (Rear)
Diff
Atessa Pump & ECU
Relay/Fuse Box
Boot Trims, Plastics, & Carpet
Boot/Fuel Release Cable
Locks & Keys
Spare Tyre
Jack & Mount
Series 3 Xenons
Front Lip
Front Grille
Front Indicators
GTR Wing
Sideskirts
Side Mirrors
Fuel Cap Flap
Bar Skin (Rear)
Bonnet Lining
Guard Lining
Antenna
Seats
Seatbelt (Driver)
Steering Wheel
Instrument Cluster
Sunvisors
Front Door Trim (Passanger)
GTR Coin Slot Cover
Driver A Pillar Trim (Driver Side)
Electric Window Switch (Driver Side)
Floor Mats
Heater Box
Heater Core
Gyro behind Airbag
Airbag Sensor
Triple Gauges
Manual Surround
Head Unit
Cheers - Chris
  • Replies 67
correction to above...
Brake Master Cylinder - $120 is actually meant to read Brake Booster - $120.. must have had a brain fade..
  • 3 weeks later...
  • 3 weeks later...
  • 3 weeks later...
Did the front bar sell mate?
Is it actually destroyed or just scrapped and no lip?
Thanks
hi adam,
yes i still have the front bar skin and definitely repairable just depends how keen you are to repair it.
Do u still have the engine bay fuse box?
contents of fuse box there but plastics assembly itself is gone.
cheers,
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
