Some guys have them on board yes.... Last time i took a set they were fkn useless lol!
Good to have you along mate! Doesnt matter what you drive, if you dont get a ride just get in with someone... I am sure someone will have a spare seat :)
already offered him the gunners seat in the money pit, he hasnt accepted. ...
still need to invest in those...
group buy for proper in car radios is in order... i needs one
trying to find reviews on this Uniden UH089NB
http://www.ebay.com.au/itm/Uniden-UH089NB-BRAND-NEW-Strong-Basic-5-Watt-in-car-UHF-CB-Radio-UH089-/110996502769?pt=AU_Electronics_Radio_Equipment&hash=item19d7e838f1&_uhb=1
If its alright, might just buy it!
Anthony bought a pair from super cheap that work pretty good.
that's right mat, I wont need one as no radio reception could be strong enough for the distance between me and the group of datsuns trying to keep up :P
I'm from North Sydney (Lane Cove). So maybe somewhere near the Pacific Motorway like Hornsby. Somewhere with plenty of parking space :D
We should get some more head counts...
pennet hills road maccas would probably be good. tbey have an over flow car park too. dunno if tjats always open or just when there busy.
then just jump on the fwy orrrr do old pac on the way :P
We could all meet at the truck stop at the start of old pac......
Being a weekend etc... Be mindful of the boys in blue and traffic on Old Pac ;)
Plenty of empty twisty roads up North to enjoy!
True, I haven't been down that road on a weekend in a long long time.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
