Z32 Afm On My Rb20De?
Hey just wondering if a z32 afm will be worth the money or give any gain on a rb20de and will it need to be tuned, has anyone done or heard of this if so please post results.
Your kidding right.......please put down the crack pipe, now when you sober up you need to realise that power gains in a Na motor are all about head work, and I hope you have deep pockets to pull power out of a 20de
Lol didn't think a question would hurt so much, now if it Doesn't hurt to ask what head work would be good I'm not expecting too much out of it just looking for a little more power
Dont even waste your time extracting power from one of nissans slowest motors ever lol. Erase the thought from your mind because NOTHING you do besides a turbo conversion will have any lasting effect and be worth it.
Would love to turbo it being a gtst with an na motor in it but sadly still on ps, the car goes alright pulls hard on other na rb20s and even 25s bit confused about why people think they are that bad, just lacks a bit of bottom end needs clutch kick to get going power comes at 4.5krpm is there anything I can do for bit of bottom end power
It's hurting because the question is just.....so......retarted it's hard to even read, an AFM simply reads and tells the ecu how much air is flowing into the engine, hence the name air flow meter, your question lines up the same as if you asked us if you put a new water temp gauge in would it reduce your water temp.....
Now to increase power in an NA there is a whole dedicated thread on it, and no I don't think you will ever hit power figures that will require an AFM change.
Dude, seriously. What do you think you will gain from putting an aftermarket AIR FLOW METER, a METER!! on youre n/a. Far out, I cannot understand or imagine how your brain must function
Z32 AFM is a standard Nissan item....they come from the z32 300zx
There is so much hatred for Na's I dident think the afm was a good idea just going by what people are telling me an thought I would ask first, all that needed to be said was a simple no,instead all I get is people being a smart arse about it and tell me to turbo it and ask if im on drugs,if I wasent a
PPlater believe me I would not go near a pos na
Whoever told you a z32 is an upgrade for a 20de needs to stop giving advise because they are stupid, and AFM upgrade is only needed when you have exceeded the current AFM's ability to read the amount of air going into the engine. Don't waste your money increasing power in the 20de because it would be so minor you wouldn't even notice a difference until you spent over 2 or 3 THOUSAND dollars.
For example : extractors and exhaust, properly setup cold air intake, coolant bypasses, bigger throttle body.... All those will cost you about $500 all up and you won't even notice a difference, will just sound different, to get better power you will need head porting and polishing, head shaving, oversize valves, cams, cam gears and then a tune, and thats just a few of the things needed and all up will cost around $3000.
Don't waste your money, build a spastic turbo motor over your p-plate years and have fun when you can drop a real engine in.
There is no hatred for N/A's. There is hatred for stupid questions. You need to stop listening to those people. The best way to get more power out of an engine is through forced induction, hence the turbo suggestion.
What I suggest you do is spend money on maintaining you car, forget about gaining more power. You can put a pod filter on your car and you gain 0 kW, but get pulled over and defected. What's the point? You're a P-plater in a Skyline. Keep the car as is, service it regularly, fix tyres, brakes, suspension, etc. Once you're off the P's, put a turbo motor in. All the money you saved from not buying extractors, exhaust, pod filter, Z32 AFM, ECU and tune you can easily go and buy a good RB25DET.
 Share
    • Vanos solenoid problems and basically all sensors die an early death
    • Yep, back in the day when you could pick up a Stagea RB25 NEO for $1,500 it was worth it. These days... just chuck your V8 or B58 in.
    • from my limited BMW experience: - they burn oil WTF (B48 FTW 170kW engine) - dump oil every 5,000km and you'll be ok.. until it drops a bearing and rebuild time. replace engine with B58
    • I would avoid the AWD motor in a RWD using a modified RWD sump and pickup. The way the pick up is positioned, you'll have oil pick up issues on hard acceleration on a track around bends. Even with a baffled, gated sump. I suppose if you don't race on a track and it's used for straight line activities or street use you might be ok.
    • They absolutely are, but the thing is, if you're only exposed to these circuits for a while, what I normally think is good driving suddenly isn't so much. I was a pussy at the Nurburgring (GP) entering corners at 180kph - the difference in the balance of the car suddenly becomes so much more pronounced and I'm still a bit regarded at left-foot braking - something I now practice on my commute. So the (dream) plan with the E90 is to make it a 325i Cup car. Whether I get there or not is another matter. In my mind the simplicity of having the NA variant and cost made it a bit more appealing. Plus, like mentioned above, I'm actually too much of a pussy for big power. Of course I f**ked up by not researching enough on the N53 vs N52, the latter being more robust without the DI system.  Suspension-wise on the BMW, and I've been reading the technical requirements for the 325i cup, basically everything except struts has to be standard - bushes are free. I figure you get about 5-10mm adjustment with the rear camber bolts which should translate to 0.5- 1.5 degrees of adjustment. So with coilovers, lowered at 30/40mm I expect I can dial out some of the camber from a drop and attain -1.5 to -2. If necessary, I could get the same effect as the M3 arms with some offset bushes. There is a limitation on ARB width to qualify, although I absolutely want to get either M3 ARBs (can't say sway incase I upset GTSBoy) or the H&R ones - both of these are the cheapest options. Like mentioned, M3 arms are on the way and I should have them fitted within the next week. How are the BC Racing coilovers btw? Reviews are mixed but I think for me they would be fine; a friend of mine uses them on his R34 for track driving and has nothing bad to say. I'm looking at these or the ST coilovers (German brand, new to me) as prescriped the in Cup spec sheet. They're both similarly priced and offer camber adjustment. It's fine but it really upsets my OCD. I've got a couple of options for dialing out the rear camber and keeping my ill-fitting wheels: raise the rear a little bit, say 5mm, that should permit -2.5 camber or drop the front to restore that slight bias of more negative camber up front (not optimal with the roads here). The next alignment won't be until at least next year and I really need to rebuild the rear subframe. For now, I'm not using it at all on the streets except occasional blasts through the German countryside. I was covering about 10k kms p/year in Japan, I expect this to now be about 3-4k. You could say buy better sized wheels, and yes, I should have. But the wheels came from the Z and price of good wheels is just insane now. Again, a couple of options: get a new set (I want 17" RPF1s) or buy two used 9.5J TEs, both are about the same price excluding shipping.
