Also i didnt want to start a massive debate over that comment but i did an aftermarket fuel pump replacement when i had my 33, had the bosch 040 put in and it didnt raise pressure all i wanted to know was what a good option for the 34 was.
Nismo drop in. Or a e85 400lph walbro will do the job Thetis drop in models for skylines on eBay for around $200ish. There is a 450-460lph version swell that's drop in. You may as well go a e84 friendly one for the future. :)
Cheers josh
Edited by Joshbigt62r
Cheers josh
pretty sure the e85 pump is not drop in. I have one, it is in but took some mods as it is a fair but bigger than the actual drop in pump, and it draws heaps more current.
I know the nismo pump is 100% drop in. The e85 460lph walbro make not be direct drop in but it is a intank fuel pump still. And still can be a drop in with a bit of basic mucking around. So yes it is a drop in fuel pump still as if drops into the tank. Just not a DIRECT drop in as the nismo pump is. keep in mind though the walbro is basically hAlf the price of the nismo.
Cheers Josh
Don't use the 040, the filter is prone to clogging and it is an old clunky design.
The Walbro 460L is overkill if you aren't tuning the car, even a Walbro 342 is more than you need, only costs $100, but still requires hard wiring the power.
I would be keeping the stock pump until you decide to tune it.
Chunky yes... I dont know why people use the 040 over the 044 as i ran an 044 with barb on the end and the original style fuel sock on the bottom of the tank, should solve that clogging issue... Worked perfectly and surprisingly wasn't loud! I blamed it for my fuel issues but it ended up being the injectors! I still run that same pump today but its now in the boot due to the external setup.
What does a 040 flow and what's a 044 flow? Sweet f all compared to the new walbro's
A single 044 got me too 350kw on an intank setup! How much power do you want to make? lol
I've got a single 044 that has been made to be a drop in. From memory I had to modify my cradle to make it a drop in. I put that in probably 5 or so years back. If I were to do it today I'd just use a walbro e85 friendly pump. Well plans are for me to make 400kw if I can. So I'll need to upgrade my pump. If memory serves me right the 044 flows 300lph but I could be wrong. 5+ yrs back memory not so great from regular weekend alcohol abuse haha. I'm more than likely still going a hta 3076r or 3582r on my built 25. Unless stao can come up with something pretty similar. Prefer to support a local bloke if I can. But FP hta just seems the ducks nuts at the moment lol.
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
