Hey guys new to the fourm and the stagea family.
I have a 2001 rs4v m35 stagea wagon.
Owned it for about a month now, and I am loving it. But something has come to my attention when im on the way to work. Or anywhere for that matter my boost seams to be restricted. When I first get in the car and drive its not a worry, untill I hit full boost (on the gauge its +1 bar just over)it will hit full boost untill i stop accelerating then for the rest of the drive will limit me to the half way line on the boost gauge, it wont let me hit full boost untill I pull over and restart the car but it will be the same thing once it hits full boost again. I took it back to the place I bought it (synergy motorsport) and of course it didnt do it. No engine lights ect no fault codes ect. I dont know is this normal? Do I just install an aftermarket boost controller or is it something more sinister.
Sorry of its stupid or had been covered before but im hard pressed finding answers.
I am in no way turbo educated as this is my first turbo car, but am mechanicaly minded.
Cheers in advance.
https://www.sau.com.au/forums/topic/427603-somethings-not-right-here/
Be careful, the gauge is not very reliable.
If you bypass the boost solenoid you should constantly get 14psi or there abouts. If the solenoid is closing it is seeing a boost spike, knock or some other fault signal, as it should only be closed when cold normally.
I didnt think the gauge was spot on, but its also an audible diffrence too. You can hear its not spooling as high as normal. I might try to get it upto synergy tomorrow. Its just weird. Other than that the car goes well and its not all the time this is going on. Most days it is but there were a few days it was fine and head heaps of power and awesome economy and then back to this. I also use shell vpower 98 thats what I found was best for it. Thanks for a quick reply too.
This happened on my car. If you turn the car off and on again it will reset it but will still happen. What I did was get a hdi ebc (electronic boost controller) and did away with stock solinoid. Doesnt do it at all now. A boost t will do the same. Seems to be another common priblem along with bov.
Well thats very interesting. Thanks all for the fast replys.
Im in morphett vale adelaide and work in mt barker. So would replacing the standard boost solenoid fix it or am I better off to go an aftermarket one? Like I said turbo illiterate haha.
Cheers guys
The solenoid adjusts the boost, from 7psi on the actuator, to 14psi when bleeding pressure off. If the ecu sees cold water temp, overboost, knock and plenty of other errors, it will lower the boost temporarily which is what you are seeing. If you don't want it to drop boost, just bypass the solenoid, if you want to find the cause of the error, you will need to get the ecu read on a consult 3 unit.
Ohhh right. So i just bypass it end of issues? Right cool. Will give it a crack and let you know how it all goes. Thanks so much for your direction on what to do. I just hope nothing catastrophic happens. WARRANTY hahaha.
Hey guys update.. ITS FIXED. Yay, went for a bit of a boot and it was perfect. Kept my ear out for any odd noises and couldnt hear nothing, just the sweet sweet sound of that turbo spooling. Thanks heaps i may actually be able to overtake a car on the way to work now haha. :rolleyes: FANKS HEAPS
Nice, what ended up being the problem?
Did you fix it yourself?
Hahaha awesome. I just bought a Stagea cross R35 skyline body for my rc car, will upload pics when it arrives from japan. And yeah Scotty thanks heaps for you help man. So happy the Stag is all good again.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
    • There is a warning that "this thread is super old" but they ignore that anyway...
    • With 10% Ethanol, we're talking 2-3% fuel consumption difference. The emissions reductions and octane boost in my opinion far outweigh this almost non existent loss.    My tanks sitting at 80%. Luckily that should go down fast as I'm on vacation again for the next two weeks.
