hey,
i have a rather big question (which is probably going to turn around and bite me, but you get that)
the friend who crashed my car tried to fix thigns on the cheap and bought a non xenon head light for my car. my old xenon still works great but the cover was smashed.
I dont want to connect the new headlight up since its non Xenon and the light differences will be completely out of wack (and i need to change the plugs to connect it)
now, is it possible to remove covers on lights and switch them over? or i it better to buy a conversion kit or just bite the bullet and save for another xenon light...
Edited by R34DeathStar
https://www.sau.com.au/forums/topic/427679-r34-xenon-and-non-xenon-lights/
Yeah you can stick the light in the oven for a few minutes @ ~100degC and the glue will melt. You should be able to pry off the lens and transfer it to your broken housing (assuming it's just the lens).
Not sure if the lens are physically different (Xenon vs. Halogen headlights).
yeah he fixed it all, but didnt listen to me about differences with the lights. eventually going to need a new bonnet and bumper. but i dont mind that, the bumper was a bit cracked when i got it.
But yeah, the lights im peeved about
haha i know i'll need them, prefer to get both done since the working xenons have cracked brackets so they wobble a bit.
But got to get the steering rack/pump fixed first.
how much are you looking at selling them for?
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
