I don't know much about these diffs, could someone help me?
I want to be able to swap from awd to rwd when i like without worrying about blowing the front diff because of different ratios, so I'm looking at swapping the centre as i think it would be easier and cheaper than sourcing an LSD that's a direct swap.
https://www.sau.com.au/forums/topic/427768-rear-lsd-options-rs4-awd/
Not quite sure what you're planning but there are a few options:
1. get a pair of GTR diffs (non V spec) that will give you a mechanical LSD in the rear and virtually the same ratio as now - 4.1:1 instead of 4.08:1
2. Get a Nismo GT LSD for your rear diff (and a Quaife for your front diff if you are flush!).
Wouldn't you just be able to use a std or nismo lsd and place in your housing using your crown and pinion wheel .
That's what I intend to do using the rs4s diff and cradle I have put in my s1 , but then swap my crown and pinion into it so ratios match my front diff, also ill get stronger axles that way and try and stop the whole snapping thing again .
I went for option 1.
I have GTR diffs partly for the LSD and also to get the GTR half shafts. Front diffs are regularly thrown way here when people stick RB26s in 2wd cars so the front diffs are easy to come by. I got a complete rear end (diff,axles brakes) for $500.
Thank you for the replies :)
Kiwi buying 2 diffs is a little on the expensive side for me, I wanted to spend as little as possible.
4bidn1 that was my idea, I was just unsure if all LSD centers fit as the r200 has so many variants from early 240z to today. Are they all the same?
  • 3 weeks later...
Manual stagea rear cradle and diff = mech lsd :) but diff ratios Are diffrent from auto stags so need to change my crown and pinion with my old one to match the front and rear ratios back up,that and get rid of the hicas
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
