Hi Guys,
Just letting everyone know my Skyline was attempted stolen at Westfield North Lakes carpark today around 1pm. Witnesses have come forward and forensics are coming for prints (there are nice ones on the window where they got in)
Now to find a whole new ignition barrel and basically a whole steering assembly as they snapped all plastic and controls.
Hope they get whats coming to them!!!
Also a shout out to William from North Lakes & Districts Towing private tow operator, this guy is a champion call out in 10 minutes and flat rate $88/hr, I recommend this guy for anyone who needs a tow Northside Brisbane.
Here are his details: http://www.truelocal.com.au/business/north-lakes-and-districts-towing/north-lakes
https://www.sau.com.au/forums/topic/427795-attempted-skyline-theft/
Yes alarm system and immobiliser system, saved it cos they couldn't start it, funny thing is they didnt steal the $1000 sound system, GPS, dash cam, prestige personalised plates or any tools that were in the car
Since you are near me pop past. I can sort the column and rekeying the car will be easy as well. Done plenty.
May pay to see if I can steal it as well.
^this right here, if he can make it run/ steal it anyone who knows what they're doing can, lucky break though in the fact they a) didn't get to steal the car and b) didn't pinch anything. Really makes me rethink ownership of a fabulous car all because a few c**ts who obviously can't afford their own want to steal them.
if they tried a basic hot wire would it be possible for me to disable (with remote) the alarm/immobiliser and touch the wires together and it start? unless they have stuffed my immobiliser in the process as my car chirps and central locking is active still?
Edited by GTS R33
Ok I am going to do something I usually do not do..
To take one of these cars for a ride you need to get past the column lock. Hammer or a crowbar is fine for that.
Then you need to get power on . Screwdriver works there once you destroy the key lock you twist to switch and you have a car .
Now if someone has done the job properly the the alarm and paging unit has triggered and the owner is on the way out with a baseball bat. If not the then the alarm wiring gets ripped out and the siren smashed. Then the car is gone.
All of this takes about 3-4 minutes max to do..
Have your attention yet?
I highly recommend you swing past Chris. I attended one of his security nights and it is amazing how fast someone who knows what they are doing can have them started even with a 'professionally' installed alarm/immobiliser.
Depends how the job was done. If it was me, nope. No amount of button pressing would stop the car.
That's no good at all.
By any chance are you a staff member that parks basically in the same spot down the woollies end out the front????
Might be a random question, but whenever I come over to the shop to do groceries etc probably 3 times a week I too always park at that end and there is always the same white 33 in the same spot. Sad to think but if it is you maybe they have been thinking about it for a while.
I got rego make and model of the offenders vehicle, am I allowed to post it on here?
Forensics have come around today and got all the prints and will be running checks. Now I can explore it seems no wires have been cut/stripped, just the ignition barrel and plastics. Maybe the alarm spooked them or they had no real idea what they were doing??? There is so many wires behind steering column its not funny. Westfield is going over footage to get images of car and trace back to people inside. If they have entered the shopping centre they will be on camera.
Depends on what R33 you mean PHT34 - there are a few regulars, i park Woolies area always but not always same spot, prob was me you are thinking of as i havent seen the other regulars for months (maybe theirs have been stolen)
Excel bogans aye. Probably down from depression bay.
Zeke bring it past and I will give it a once over.,
Might swing past next Saturday morning again if that works for you.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
