Howdy peeps.
I do some work for a fire company and we quite often have perfectly good fire extinguishers that we cannot sell due to legislation. These cylinders work perfectly. We have everything from small 1kg (perfect for a car) to massive 9 Litre air/water and 9kg powder.
If anyone needs an extinguisher please let me know. I am located in Sherwood (if you want to pick up) but am often at Club events if that is easier.
Cheers,
Ben.
https://www.sau.com.au/forums/topic/427943-free-fire-extinguishers/
overwhelming response is overwhelming!
Martin, how does a 2.3kg sound? Got a nice one here. Everyone else, your request is noted and I am preparing your cylinders now.
May have to organise to meet at the next dinner. While I am happy for the occasional visitor, I don't want to have to stay home every night waiting for people to rock on over. Plus I don't want to wear out my remote boot release :)
Tony/Mike, is there a dinner this week and if so, when and where?
Benno. Call me. Need to talk about stuff
Tonight at Vroom dude. Monthly meet.
oh crap!
I have a bday dinner in the valley. But...I can stop by Vroom.
So, here is the deal. I will bring everyones extinguishers to Vroom tonight. If you are there then great. If not, you will need to let me know how you wish to collect them. ps. I don't do downshit(downshift) meets.
Cheers,
Ben.
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
