Hi all,
I am in the process of getting some bonnet dampers in to suit R33/R34 and possibly S13's. If anyone is keen on a set I will place a larger order so I can get the price down.
At the moment it is looking to be around the $70 for a black set and $100 for a carbon set.
Will know exactly how much when I place the order, the $$ is tanking which is a bit crappy.
This is just a EOI at the moment, still a couple of weeks away from confirming anything.
Who is keen?
https://www.sau.com.au/forums/topic/428030-eoi-skyline-bonnet-dampers/
I'd be keen for a set. Been meaning to getting some just never got around to it. I assume they're universal? So no specific brackets or anything..?
Im interested. I have a 180sx (240sx kit because its american) on mine and the struts were to strong and slightly to long so I couldnt use them. The ones I do have are too weak.
Got any pics of the kit you have in mind?
Ill ask about 32's as well.
These dampers are only for GTST/GTT, the bonnets are around the 17kg mark and the dampers are made for this weight.
If I get enough interest Ill see about dampers for GTR's. Can anyone tell me the weight of a GTR bonnet?
I want to order some sample sets for different models so ideally I would like some willing people to test fit these.
ER34
R32 GTST
S13 Silvia
S14 Silvia
I am assured these work with these model/weight bonnets.
If you have the above model and would be keen on a set shoot me a PM. A small deposit will be required.
Here is a pic of what to expect:
First in with PM and deposit gets it :)
I'd like to have the cars at my place so I can check install and operation.
Tried to PM before but got an error that you couldn't receive messages.
Matts probably closer if it is for a test fit! So try it out and let me know how you go :)
Either way if you can make them work i am keen! Would be pretty handy considering the amount of time i spend under the bonnet lolz
Agreed. More room with a higher bonnet plus no obstruction when working. WIN WIN!
    • Welcome to !
    • As I've said elsewhere, I am using the stock intercooler piping path in the engine bay, and a return flow cooler, and making ~250 rwkW (without any effort put into trying to turn it up past there just yet) and expect to be able to make some more, and frankly, I would be perfectly happy with 260-270rwKW. This is peak road Skyline usability territory. You go past there and, sure, the car will snap necks more when it's on boost, but it will also break shit all the time, cost a (even larger) fortune in tyres, etc etc. Anyway, I also do not like the over-the-fan pipe path, and you don't have to do it.
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
