Ok, so my ps3 has been playing up a bit lately and it keeps coming up saying data is corrupted and has to restore. kind of getting over having to do it every few weeks so I'm thinking I'll just get a new hard drive. I reformatted it a while back but it was still not right afterwards.
so what I would like help with is choosing a new drive, and where to get them from for a decent price. I currently have a 250gb in there and I have plenty of room left on it. I don't have many games that I play so I still have plenty of room on it, so size doesn't really matter. price matters more
https://www.sau.com.au/forums/topic/428201-need-new-hard-drive-for-ps3/
pretty sure most people use SSD's these days. but pretty much every 2.5" SATA hard drive will do the trick, just stay away from hitachi and western digital green drives if your going for a hard drive. people dont seem to like the Samsung 840 SSD, but mines been running fine for some time now.
i use 2 places to get my PC gear from, PC Case Gear is one, but their freight can sometimes be pretty expensive. the other one i use is Megabuy, they work out about $3-4 cheaper on some items, but they use Star Track Express ( i personally favour them).
http://www.megabuy.com.au/wd-wd7500bpkt-scorpio-black-750gb-25-sata-hard-drive-p257136.html
http://www.pccasegear.com/index.php?main_page=product_info&cPath=210_267&products_id=16837
I thought the ps3s had problems with ssds??
I bought a 500gb from d-comp.
just ask your local computer shop.
The only local computer shops I can get to are dick smith (they know nothing) or harvey norman (they are ok, but don't keep much stock of hard drives) because of work. I leave for work at about 7:30am and get home after 6pm, so that narrows my options down a bit.
Buy online. I got mine from Mwave.com
something like this would probably get you by if your not interested in having rediculous amount of space. Slightly faster then standard and slightly more storage. But then you can go cheaper still if you want to stick with 250gb and/or you dont want to bump the speed up to 7200rpm
http://www.mwave.com.au/product/sku-aa20468-wd_scorpio_black_320gb_25_satsii_7200rpm_wd3200bekt
They don't necessarily have problems, but the benefits of a SSD aren't recognised as much with the PS3.
Comparison videos and reviews of using SSD in a PS3 and most of them will conclude that it's a waste of money.
Update: did a format in the old drive last night. Installed my games this morning. It was playing up a bit still. Restarted it and it wouldn't turn on. Lights came on but no-one was home. Wouldn't even boot in safe mode, etc. turns out I'd bought extended warranty when I bought the system and there was still about 2 years left, so it should get fixed/replaced for free.
That's Good News ,I just hope it doesn't take them 2 months to fix it
my mate who runs the place I bought it from said that the last one they had an issue with was just replaced without them even having to send the old one away (he then took the old one out to the local shooting range and blew it to pieces), so fingers crossed. he said mine faces the same fate if it gets replaced, lol.
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
