^ Pretty much
Thats why I originally didnt say 'this will definetly be it' but it is most likely one of those things. I suppose if you wanted to test the heat exchanger you could remove the coolant lines, link them together and then run the car and see if the problem gets worse, or if you get oil leakage out of the coolant ports in the heat exchanger. Just let the thing warm up easy
Otherwise if its head gasket/head related then the only option is to pull the head off.
  • Like 1
https://www.sau.com.au/forums/topic/428302-oil-in-radiator/#findComment-6920489
Well, if you want to look at it that way, then yeah, it is an expensive way to diagnose a problem. But I tend toward the expectation that people on here who ask these questions need a mechanic to do the work, so they will then take it to a mech with the "oil in water" story. Whether the head gasket gets replaced or not would then depend on what the mechanic finds.
But I take your point.
https://www.sau.com.au/forums/topic/428302-oil-in-radiator/#findComment-6920541
there is tests you can perform to determine if the hg is blown or not whilst the motor is intact,taking the(factory) hg off usually destroys it and it maybe harrd to pick up where it blew(thats if it blew at all)
its just the way it is
https://www.sau.com.au/forums/topic/428302-oil-in-radiator/#findComment-6920628
Over the course of a weeks driving does it use much coolant?
Not the same car, but my Commodore had similar issues after I replaced the radiator and thermostat, new fluid etc.
I swore I'd done the head gasket, as after a few days there was little bits of oily crap on the rubber of the radiator cap. Then I checked the overflow, and it was in there too.
It was using around 100ml of coolant a day.
I found a heater hose that was a bit loose, and then dumped the coolant and replaced it. Its been fine ever since! The only thing I could think of was either the new radiator had a bit of crap in it, and the fresh coolant might have dislodged some buildup from the engine somewhere.
Check the overflow bottle to see if its got the same stuff in it
https://www.sau.com.au/forums/topic/428302-oil-in-radiator/#findComment-6920670
(to op 2nd answer above )not time to panic yet strongly suggest you get the engine tested before you start tearing the motor down and then having to work out which TAB you can rob to pay for it :-)
Edited by StevenCJR31
https://www.sau.com.au/forums/topic/428302-oil-in-radiator/#findComment-6920679
QUOTE
/QUOTE
Oil in water and combustion gases in water are two separate things though. I don't think there's a "test" that will tell you that your oil in water problem is definitely HG or not.
Edited by GTSBoy
https://www.sau.com.au/forums/topic/428302-oil-in-radiator/#findComment-6920688
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
