^ Pretty much
Thats why I originally didnt say 'this will definetly be it' but it is most likely one of those things. I suppose if you wanted to test the heat exchanger you could remove the coolant lines, link them together and then run the car and see if the problem gets worse, or if you get oil leakage out of the coolant ports in the heat exchanger. Just let the thing warm up easy
Otherwise if its head gasket/head related then the only option is to pull the head off.
  • Like 1
https://www.sau.com.au/forums/topic/428302-oil-in-radiator/#findComment-6920489
Well, if you want to look at it that way, then yeah, it is an expensive way to diagnose a problem. But I tend toward the expectation that people on here who ask these questions need a mechanic to do the work, so they will then take it to a mech with the "oil in water" story. Whether the head gasket gets replaced or not would then depend on what the mechanic finds.
But I take your point.
https://www.sau.com.au/forums/topic/428302-oil-in-radiator/#findComment-6920541
there is tests you can perform to determine if the hg is blown or not whilst the motor is intact,taking the(factory) hg off usually destroys it and it maybe harrd to pick up where it blew(thats if it blew at all)
its just the way it is
https://www.sau.com.au/forums/topic/428302-oil-in-radiator/#findComment-6920628
Over the course of a weeks driving does it use much coolant?
Not the same car, but my Commodore had similar issues after I replaced the radiator and thermostat, new fluid etc.
I swore I'd done the head gasket, as after a few days there was little bits of oily crap on the rubber of the radiator cap. Then I checked the overflow, and it was in there too.
It was using around 100ml of coolant a day.
I found a heater hose that was a bit loose, and then dumped the coolant and replaced it. Its been fine ever since! The only thing I could think of was either the new radiator had a bit of crap in it, and the fresh coolant might have dislodged some buildup from the engine somewhere.
Check the overflow bottle to see if its got the same stuff in it
https://www.sau.com.au/forums/topic/428302-oil-in-radiator/#findComment-6920670
(to op 2nd answer above )not time to panic yet strongly suggest you get the engine tested before you start tearing the motor down and then having to work out which TAB you can rob to pay for it :-)
Edited by StevenCJR31
https://www.sau.com.au/forums/topic/428302-oil-in-radiator/#findComment-6920679
QUOTE
/QUOTE
Oil in water and combustion gases in water are two separate things though. I don't think there's a "test" that will tell you that your oil in water problem is definitely HG or not.
Edited by GTSBoy
https://www.sau.com.au/forums/topic/428302-oil-in-radiator/#findComment-6920688
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
