A bit of background first.
I have recently done a DIY minor service, cleaned the throttle body and installed a SxExCx grounding kit and since then the Check Engine Light (C.E.L) display constantly while driving. And when the car is given the beans, the VCD and SLIP lights come on and stay on; only on occasions, not every time which was odd.
The car drives perfectly, no misses or leaks, gear shifts are great. It actually feels heaps better since the service/clean/grounding kit. So it is very odd.
Please also note, I performed the ECU reset and could not clear the C.E.L.
So today I had my car scanned and I got back 4 error codes.
ENGINE: ign signal primary
ABS: abnormal batt voltage
ABS: engine signal 1
CVT-TRANS: starter relay circ.
The codes were deleted/reset but the engine/slip/VCD light came back on while driving home. I will be taking the car back for another scan and a better look into any of the problems.
Does anyone know what would be causing these problems and how to fix them? Any advice would be great.
Cheers,
https://www.sau.com.au/forums/topic/428473-error-code-help/
All those codes may have been there for a while, I would check the new error, getting the code number once it's scanned and plug it in to google. Was it a local Mech you went to?
Nissan's Consult3 units give a much more detailed description of faults (sometimes) and it can be worth taking it to Nissan for a scan, but at $150-200 it isn't cheap. The Chinese Consult3 knockoff I use works well on all the ecu's in the car, I also have the Osirus cable which gives good descriptions of engine codes. Other units can be hit and miss, and it would depend if the mech updated the unit with later Japanese protocols.
The slip light could be caused by mismatched tyre sizing also I think. So all three lamps come on together?
https://www.sau.com.au/forums/topic/428473-error-code-help/#findComment-6924965
My brothers a mechanic, and he scanned it at his work. They had a brand new scanner that had the option for Infiniti so figured it would work.
He said some of the codes could have been old. Will find out tonight what the outcome of the rescan is.
https://www.sau.com.au/forums/topic/428473-error-code-help/#findComment-6924980
If the codes re-occur, I would be tempted to disconnect the grounding kit and see how it goes, since they seem to be voltage related issues. Also check you didn't leave any factory ground disconnected.
https://www.sau.com.au/forums/topic/428473-error-code-help/#findComment-6925051
I have my grounding kit going on the tbs to negative terminal and also engine block n terminal n chassis. My tbs are more responsive and easier to drive. Pretty sure it isn't only me who thinks the grounding kit works
https://www.sau.com.au/forums/topic/428473-error-code-help/#findComment-6925729
Thanks for the input guys.
So the rescan came up with the same 4 codes. It points to a voltage issue which could stem from the grounding kit supplying higher voltage which the ECU cant deal with so the engine light comes on. Its not doing any harm to the car, its just an annoyance. So I will be disconnecting the grounding kit to see if it solves the problem.
It would be a shame as I have noticed a difference since putting it on. Its marginal but know how the car felt and drove before and after, its not just a placebo. The factory grounding is weak, just one connection from the battery to the chassis and then a couple from the chassis to certain components. Adding this grounding kit to have connections from the battery to the engine and from there to other point and the trans has to be better right.
https://www.sau.com.au/forums/topic/428473-error-code-help/#findComment-6925807
Grounding kits aren't necessilary bad, but they need to be designed properly. If someone just throws a kit together without much thought, you can end up with earth loops which will cause all kinds of voltage/sensor related issues.
From what I have heard, the grounding kits can help a bit with auto transmission shifts. But you would be much better off cleaning the factory grounds and invest in a shift kit for the transmission.
https://www.sau.com.au/forums/topic/428473-error-code-help/#findComment-6926453
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
