Hey leesh,
If you back is sore alot you should go and get an mri done to see what shape your discs are in. Also try to fit in some riding it will help both your abs and back and being cardio ahould help your definition around your abs you want. Just do 15 mintues on the hardest setting you can keep up 60 rpms
Got my CT scan results, said similar to the xray results in regards to the narrowing, but apparently not impinging on a nerve. I did ask the GP why I'm getting a pain running down my leg in certain positions though... Anyway I have 5 physio sessions booked to try and sort things, hopefully will be more successful with this information
20/04/15
Deadlift
20kg x 10
40kg x 10
50kg x 10
50kg x 10
Bench Press
25kg x 10
40kg x 5
50kg x 2
56kg x 1
50kg x 4
45kg x 9
45kg x 6
30kg x 25
Bicep Curl
15kg x 10
17.5kg x 10
20kg x 10
25kg x 6
22.5kg x 10
One reason is that 75kg is not what I should be 1rming. Put my volume sets into a 1rm calculator and my 1rm comes out at nearly 100kg. Like I've said previously, I can squat 60kg for over 20 reps, so it's not a strength issue...yet I'm just getting one rep of 75kg. I know it's technique... I just don't know what I'm doing wrong with the heavier weight.
Edited by L33SH
One reason is that 75kg is not what I should be 1rming. Put my volume sets into a 1rm calculator and my 1rm comes out at nearly 100kg. Like I've said previously, I can squat 60kg for over 20 reps, so it's not a strength issue...yet I'm only just getting one rep of 75kg. I know it's a technique issue; I just don't know what I'm doing wrong with the heavier weight.
Edited by L33SH
Unfortunately depression is something I know to well having struggled with it most of my life and yes I find it does make it quiet difficult to workout/function with it.
I'm having trouble with it myself at the moment and it shows up mostly in my workout, I'm not sure what to do about it either this is my third year trying to loose some fat and look/function "normal" and I'm yet to get my mind working with me.
I hope you find something that helps with it I'm looking at some group training sessions right now to force me to do my best maybe you should try the same?
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
