So it would seem that our Shell will be getting her Skyline back next week !!! :woot:
This Demands a Cruise in Her Honour and also to Blow a bit of High Octane Exhaust in Skippy's face as Punishment for taking her 34 off the road for soooooo long...
So how bout it Peeps?
I propose a meet at the Hindmarsh Bus Stop at 12pm ( for the late risers amongst us. ie. SHELL :) )
Leave around 12:30 - 1pm and go for a Respectful fang around some of our Favourite corners / scenery...
Uriarra - Cotter etc and perhaps finish up with BBQ Roadkill somewhere. (Pine Island?)
I am merely the instigator and will happily leave any or all Options / Changes / Better ideas to Shell herself to Update as she sees fit. (Date, Time, Location...whatever)
But yeah... We Should All Go For A Drive !!!
(and if the Shell 34 factor aint enough for you, it's my B'day next week too so just do it for me B!tches.) :P
aaaaaaand...GO!!!
https://www.sau.com.au/forums/topic/428518-cruise-for-the-shell-of-it-date-tba/
Oh thank god you didn't make it Saturday cos I have a massive piss up that work is paying for :D
Sunday I can do!
And it's your birthday Rob? Well, say no more! Lock it in Eddie!
Excellent!! That was Lucky...phewww... But you had / have the option to change at will anywho... :P
B'day is Thursdee... I'll be 83. :(
? :ph34r: ?
NoCanDoo - GTR off road
Ummmm... 34!?! Do it. Would be nice to see a few 34s crusin'. :D
Rosie, Shell, TokyoTaxi, Elle, Azathoth, B-Rice, The34T ???...
Would Be Awesome !!! Please???
Edit* Richard, I'll sell you an RB20 10psi Actuator and install it for you the day before... :whistling:
Thnx mate - doing the 34's cam cover seals, plugs, valley plate and 02 sensor on the Friday (19th)
Happy birthday too. Had mine on the 1st :D
:cheers: I have a Special Socket for the O2 if you need it. Didn't you do the plugs back when you snapped the old valley cover off?
and yes... I do owe you a Public H-B'day to you! (despite my 24hrs late Txt to you.) Sparkler > :merli: < Party Hat
I'm in.
Yaaay!!! :woot:
#@Trozzle bring your bike.
This^^^
keen to meet some people...im in
Awesome... You won't regret it. :)
i can't say no to rob, ill come out in the yaris if the gtr is not back lol
You can say No, but it goes on your permanent record. :P
post-78856-0-85399500-1373681535_thumb.jpg <<--- Something like this...
  • Like 1
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
