Happy birthday Rob!
Long time guys but I been trying to further my career and that doesn't let me get online very much.
Car is running great now after having the gearbox out again to replace a shattered spigot bush and a bent pressure plate. So I'll be sure to get out and say hello to some peeps.
Happy bday Rob.
Cheers Eric!
Oh and happy bday guy!
Thanks ZEBU! :)
Happy birthday Rob!
Dafuq??? KASKO!!! (funny how when you knock on someones door enough, they can't ignore you forever.) :D
Welcome back Daniel.
So I see you managed to log in then, Mani :D
Date changed to TBA for now!
Haha I got Matt to message you because I had no clue how to log back in. Had to go full version and do it. Thanks for that Shell.
I also need to renew my membership
Has the blue NSW thing disappeared off my posts?
Love ya work Shell !
How could I ignore you!?
I still owe you one for leaving you stranded at the airport haha
Hahaha... Memories (scars). I still owe you one for that too ya Fargin Canole! :)
It's still there... for now lol
Look out for an email tonight with a renewal form ;)
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
