Yeah so... I don't quite own a skyline but the Nissan I own shares a lot of R33 GTR parts.
It's a 1988 Z31 300zx wide body
Converted to a VH45DE infinity V8
GT35 xr6 turbo
Link standalone
R33 GTR brakes
GTR 5 speed
N200 long nose 3.7 LSD diff
GTR bucket seats
Tube & fin IC
Runs on 6 pound of boost and creates approx 420rhp and the car only weighs around 1100kg
It's a pretty hairy ride.
Plans - Motor
Moving up to 550cc E85 compatible injectors
Custom fuel tank & app e85 compatable pump
Increasing the spark (havnt settled on how yet)
Custom log manifold
Possibly twin turboing...
Other loose ends
Move the fuse box and relays into the cabin
Shave the engine bay
Look into running 355/332 brake upgrade and bias valve
Pics to come
https://www.sau.com.au/forums/topic/428874-sleepers-z31-vh45-turbod-300zx/
welcome to the forum mate, keen to see some pics and more info on the car
as mick said 555cc will be on the low side for corn fuel! better of going 1000cc straight out and u never have to worry. Saying that on 420hp already you could easily throw another 10psi into that motor and make plenty on pump gas as it is
  • Like 1
Sounds like an awesome build. What are your plans with the car? Track or street?
As everyone else has said, got straight to 1000cc injectors. 550's will be too small if you plan to take it further.
Hurry up with the pics!
Cheers for the comments.
Car will be used mainly for track. I'd like to stick to pump but I'm worried about pinging and it's comp being 10.1:1 blowing a ring. I havnt been able to find someone or a build with a vh45 going more than 10-12psi so that's why I was leaning to e85.
And yeah wot doesn't Take long before I'm at the servo again lol
The 550cc's are enough for 600, currently I'm on 380's an only 91% duty cycle and without sequential injection (I think that's the right term...)
I simply can't fit 1000's in there... Clearance is an issue to the inlet manifold.
If I do go TT ill be making a ffim where I'll have all the room in the world but for now I'll max out what's there.
I'll see how it holds up on 10-12psi on 100 ron, then look into e85.
600-650 is the plan, anything more simply wont get to the ground.
Also looking into 18x10 18x11.5 rims.
Thanks guys. I'll try uploading a pic of it on boost.
It does sound nice!
Thanks Luke GTR, I don't know how that didn't come up when I searched it... Even on nico forum there isn't any details. Anyway I'll be buying them, now I have to find a set of better coil packs.
Then I should be able to use what I have to easily 5-550rhp :D
Um yes lol
Starter motor relocated to the other side and bell housing welded back up, adapter plate made, custom shifter, ditched the transfer case and made new mounts.
I can't take and not taking credit for the build, my mate built the car and I bought it off him.
First ever car I've bought not built... But it's been done extremely well.
Anyone know of a better coil pack that fits a 45?
And also will there be another bbk group buy???
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
