I too blocked off the top vac line from the solenoid to the Tee-piece. A lot of people says that this has no effect on performance but I think this should be looked at as the solenoid is obviously hooked up to the ecu, and by eliminating this device, would it effect the way the ecu makes it's calculations? Ive noticed my '97 serII is drinking a bit more after I blocked off this line.
The car will obviously still run, but what I'm really concerned with is if the engine is gonna run leaner/richer......i.e does this boost solenoid effect the way the ecu deliver the messages to the fuel system.....I doubt this solenoid is an independent device and it could be associated with the rest of the system in some way, would it alter the other parameters by turning it off?
Chrisgero, this happened to me too, but what actually happened was the vac line from the boost controller to the actulator wasnt tightened properly and popped off when I was givin it, the bitch peaked somewhere around 20 - 25 psi..... mine too made a huge-ass 'POP' as if the turbo had exploded, I freaked right out.
Blocking off the hose to the solenoid will just give you no boost increase as it stops the bleed off of pressure. Bypassing the solenoid is asking for problems as the solenoid itself is also a restricter, bypassing it will just allow uncontrolable boost. The is no feedback from the solenoid to the ECU as it is an ECU output, simply switched to ground by the ECU to turn the solenoid on, thereby letting the bleedoff occur. The only reason fuel consumption would increase by turning the solenoid on all the time, or sooner, is because boost is increasing earlier, therefore more fuel is needed.
  • 4 weeks later...
whats the best way to adjust a bleed valve anyway? ive just bought my car recently and it has one on it but i haven touched it. its supposedly set to 7psi but ive never really seen it go past 5psi. im thinking that the bleed valve is closed completely and seeing that the solenoid would have been disconected im just on low boost all the time.
  • 1 month later...
did this mod jus then haha wat a good find! scared to do it at first but yeah worked out all good i didnt even use that lead wire.. i jus cut the black, stripped it and wrapped it around the bolt haha same thing... gg paulr33 wid this mod
haha no problems. glad your enjoying it. someone else had done it long before ive have but they never posted how to do it so i cant take the credit for all of it, i just tried it once after looking at the rb25 diagram and thinking how it could work and then tried it and it worked. enjoy
by doing this mod , will it effect the running of my power fc (which i havent installed yet)?
mate ive got a power fc and i done the boost thing and the only thing i see going wrong is my petrol ;) hahaha but other then that love it..
  • 2 months later...
Hey all i just signed up cause i got a 94 r 33gtst
Just askin but when i got the car it wont run over 5 psi i tried a little pipework and ran it wayyyy past 7 pound cause the overboost mechanism kicked in lol. (put it back soon after)
i wanna do the wire job to test it but does neone have an idea on what could be wrong with my car?????
  • 4 weeks later...
lol i thought i broke my car till just now lol!!!
i've chopped my wiring up now to =(
ahhh well least now it might work ???
dont know if this will help ne1 i got some of those lil screw down terminals from jaycar i think they cost a $1.50 made doin this a breeze and its also reversible if i want =)
HI buddy,
Sounds like a quick and easy mod. Im just wondering it you can do it to an auto??? i have r34gtt tiptronic. i think they run slightly higher than standard boost when stock?? or is it just always on full boost no step up in boost levels after certain rpms like the step which this mod gets rid of?? I am not too sure
i would really like to know though coz if its the same as a manual i will do the diy mod asap.
any help would be appreciated
i got no idea bout auto's/34's etc.. but when your driving around do you get extra boost at 4500rpm ?
If you do, then you should be right to do the mod. Either way though, it only takes a second or 2 to fix back up if it doesnt work.
Could someone please send me a link for the type of switch I would need to use for this setup. I want to put one in so I can flick it one way for 5/8psi other way for 8psi..
I've bought one from dick smith that has 3 prongs on it and I was guessing it should work however I can't even get it to work with 2 little LED's and a battery.. so either I suck - or I've bought the wrong switch - which I think is the case (hopefully)
Never mind - i've sorted it myself - i've purchased the following:
http://dseau.resultspage.com/search.php?p=...34&site=&w=7701
for anyone that doesn't know anything about electronics you need a SPDT switch which is the following:
SP = Single Polarity - DT = Dual Throw - which pretty much means that if you flick it one way 1 thing turns on - flick it the other way the other thing turns on..
good luck!
installing a switch as i'm doing will stop this issue..
also - it only runs 8psi when it's spooling.. so really.. it's up to you and how hard you want to drive it...
shouldn't be to much of an issue.. most people drive with 10psi aftermarket..
thing you should be more worried about is the boost solenoid - having 100% grnd all the time..
put a switch in and only use it when you want to..
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
