1995 Nissan 180SX with RB26DETT Built Engine
Power:
380rwkw @20PSI (1240nm Torque)
Car is on 98 Octane (E85 will make more power)
Engine:
Rebuilt R32 Vspec RB26 Forged bottom end balanced crank
Custom Smoothed & Painted Engine & Bay
Custom Re-structured front to fit alloy radiator with clutch fan
HKS Adjustable Cam Gears
HKS Mild Cams
Ported Head/Exhaust Manifold Metal Gasket
N1 Oil Pump
Gates Racing Belt
850cc Injectors
Twin Garrett Roller Bearing Dash 5 Turbos
Custom 4” Intercooler
Custom Intercooler Piping
Custom Intake Piping
2 X Drift Pod Filters
Custom Blow Off Valve Piping
52mm Alloy Radiator + New silicon hoses
Drift Oil Catch Can
Oil Cooler
Oil Filter Relocation
Custom RB26DETT Oil Sump
3.5” Exhaust with Trust Dumps
Wolf 3D ECU with hand controller
Transmission:
RB25 5 Speed Gearbox
Custom Gearbox Mount
Heavy Duty Clutch
Suspension & Wheels:
5 Stud Conversion
4 Pot Front Brakes
Slotted Front Rotors
Heyman Copy Drift Knuckles
Sideways Suspension Adjustable Caster Rods
Cusco Adjustable Coilovers
GKtech Wheel Spacers
17” Koya Drifteks (fluoro green powdercoated)
Body:
White with matt black bonnet with pins, no front bumper, vertex rear bar and skirts, rolled guards, a few dents here and there can be fixed, rear passenger side had a small bump, has been popped back out and sticker bombed.
Interior:
CAMS Approved Half Cage (Weld in)
Drift Suede Steering Wheel
Drivers Side Autotechnica Bucket Seat
Passenger Side S15 Front Seat
Autometer Boost, Oil Temp, Oil Pressure gauges
Havoc handbrake
Has been on the track once last year. Water temp never goes over 88 degrees, mechanically been perfect, Timing Belt changed not even 1000kms ago so it does need a tune because the timing is out
Its an extremely fast car, no test pilots, depending on the time ill take you around the block. Located in Mill Park
Asking $13k Ono
Call 0401350991
guessing by the fact the radiator support bar has been cut to fit the radiator, and the fact it's a 380rwkw rb26 180sx for 13k, I can comfortably say No.
  • Like 1
  • 3 weeks later...
Nah, it's just I hate finding cars, getting hopes up, contacting the sellers just to find out there for sale. Makes it easy for all viewing if they know if the car is for sale still.
that doesn't even make sense
  • 11 months later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
