Hello im from sweden, i join this forum becuse my problem.
I have a Skyline R33 GTST RB25det 1994.
I cant get my sparks wet with fuel? sometimes 1 or 2 sparks get wet but not the other one.
Okay, im not a idiot, hehe, i have check this things:
- New Whalbro fuel pump.
- New Jecs 720cc injectors.
- New plenum intake.
- Kompression 12kg at all cylinders = OK.
- Fuel in the tank, 1/2 tank.
- I get fuel to the injectors.
- i have remove the injectors and rail and try it, and all injectors work fine (spray nice).
- The cams are right, even the crank.
- i have look at the CAS, even meet it up with a multimeter (voltage/ohms 600) and its seems to work nice.
But, im thinking about the fuel pressure, the injectors want 3bars pressure, how mutch is it with the original fuel pressure "sensor"?
Im thinking to change this but i dont know if i need, its seems to be okay pressure now to, and all the 6 injectors open nice.
But i can't get all sparks wet? The engine dont start becuse this, with startgas the engine want to run but it need more fuel.
If it take in air between engine/intake, could it make this problem to?
Hope all understand my english, im not best at it..
// Emiiilz from Sweden. :)
Edited by Emiiilz
hmm i mean.. When you check if the engine get fuel you check the spark, if the spark are wet/dry with fuel its get fuel into the engine.
Hope you understand what i mean. I can't understand why, becuse the injectors work and spray, i thinking about the fuel pressure, but
original its should be 3 bar and thats most be enugh? injectors want 3 bar.
I think he is trying to say that his spark plugs are not getting "wet" as in no fuel is being injected into the cylinders. When he uses start ya bastard or similar to try and start it it works.
Has the car been running fine before this, and the problem has just started? Or have you just put a new engine in etc?
It sounds a lot like the fuel lines have been hooked up backwards, which is fairly easy to do and a very easy fix :)
<p>He already said he took Injectors out and they spray fine....but he hasn't said if ecu is upgraded to match 720 injectors...though if it isn't they would be dripping wet..lol </p>
thanks for the help but i have try all this allready. The map is for 720cc injectors, i get it from Haltech, i run that ECU.
i have try others map to but no diffrence. And the fuel lines are right and the whalbro pump is cable into the stock harness.
i have try to put the ignition coils out to and try but no diffrence. i cant just understand this...
As I asked before. Was the car running fine before these upgrades or have you never had this car running?
sorry i miss this. Yes the car run before but then its was nearly original in the engine, i have rebuild the engine now with some
parts like Haltech Ecu/mainfold/turbo/plenum intake/injectors/engine gasket 1.3mm/exahust/intercooler and more things...
I have a failure code at the TPS, i cant se voltage in the computer at it, but can this have with my problem to do really?
Now the car start? i have dont do nothing, the car just start when i turn the key?? icon_question.gificon_eek.gif
And its go nice?? i have drive the car and its work fine, haha whaat? icon_question.gif
okay, im very happy but i cant understand this problem.....
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
