Parting out R34 Gt-t street/track car
  • All parts located Ipswich, Qld
  • All parts are from R34 Gt-t unless otherwise stated by Brand or model number
  • All parts as described or money happily refunded
  • All prices are firm or VERY near offer - lowballers can E.A.D
Payment: Cash on pick-up or postal money order. Strictly NO bank transfer or paypal, don't ask.
Post: Will post smaller items at buyers expense - may take a couple of days to organise package and post.
All inquiries via PM or phone 0413 863 207
What is listed is what's for sale, there may be some factory bits still left on the car that may be of use so make an inquiry.
R33 GTR Brembo brakes. Slotted front rotors, EBC pads, plenty of life left in rotors and pads: $1750
R34 A/C compressor: $100
R34 alternators: $75 each
R34 CAS: $150
R34 ABS module: $250
Instrument cluster: $100
Triple centre gauge set: $100
Apexi AVC-R boost controller, blue screen complete with harness & boost solenoid: $250
HDi Boost Controller and gauge, complete with harness and solenoid: $125
AP500 electronic cruise control, complete with steering wheel thumb controls and instructions. If Qld, this setup can be fitted by Chris Rogers. Suit most cars: $250
Power steering pump: $100
GT-R Blow off valve with flange to suit RB25 or RB25 Neo: $75
RB25 Neo fuel rail with Bosch 1000CC injectors & loom: $400
Turbosmart fuel pressure regulator with gauge: $150
Braided brake lines to suit Brembo installation on Gt-t, Gts-t or Silvia. Complete with banjo bolts: $100
Apexi N1 lightweight coilovers to suit R34 Gt-t. These have recently been re-valved by Murray Coot for Australian conditions, in VERY good condition: $1000
Coilpack and loom: $150
Genuine Z32 AFM with plug: $250
Selby heavy duty sway bar, 4 way adjustable. Suit R34 GT-t with or without oversized sump: $150
Front and Rear lower control arms: $100 pair
Rear half shafts: $100 pair
Peterson oil cooler and filter relocater. A rare item that takes the oversized oil filter. Braided lines and fittings: $400
Front adjustable strut brace, unknown brand: $40
Custom big horsepower tail shaft with serviceable universal joints: $300
Stock clutch fan with supertight clutch: $100
Radiator shroud: $100
A/C condenser: $100
Koya drifteks 17x9 +35 offset. One wheel has a crack in the spoke, all wheels are round and true: $300
Pair only, Enkei 17x9 +37 offset. Pearl white paint polished lip, will clean up nice: $100 pair
Nismo style catch can, polished alloy in excellent condition: $75
RB25 Neo gearbox complete with shifter. Suit R33 or R34: $1250
Sparco racesuit - EXCELLENT condition, worn very little. Suit tall, slim driver around 6'1" to 6'2" mark: $300
Power FC with hand controller, suit RB25 Neo GT-t or Stagea: $800
https://www.sau.com.au/forums/topic/429285-r34-gt-t-streettrack-car-part-out/
Hi Noel,
You wouldn't just happen to have the Neo R34 GTT boost sensor?
Looks like this
Located at the back of the block and the tube to it is normally blocked off.
  • post-13786-0-79055200-1375861782_thumb.j
would appreciate it :thumbsup:
  • 1 year later...
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
