ITEM: 1989 R32 GTR in rare gunmetal grey.
- Car is complete including gearbox except for engine and intercooler. Currently registered until 17th August 2013.
- Externally stock with all badges and rear wing removed
- Body is in good condition. has a football sized dent in the RHS rear 1/4 that needs to be fixed. I had planned on fixing it and repainting the whole car.
- Stock interior in average condition
- Stereo, air con system and controls have been removed before I bought it. Has 5 x Greddy black-faced electric gauges in place of air con controls and radio.
- Stock R32 GTR wheels with tein suspension in average condition.
- Aftermarket LSD
- Microtech Lt12s ecu (wired for 6 or 12 injectors) with 6 x LS1 coils
- Complete E85 fuel system less than 50kms old consisting of Walbro in tank pump=> surge tank with 3 x 044's => distribution block into twin -8AN fuel lines to twin fuel rails (not included). Return line, All new Earls teflon hose and fittings.
- Battery relocated to boot.
- 3.5" custom stainless steel drag exhaust
Just needs a complete engine & intercooler fitted to get going.
Selling car as a whole ie: I will not sell off any parts already fitted to the car. ie ie: anything listed above this line.
PRICE: $8,500. No offers or time wasters.
LOCATION: Car is currently in storage in the Blacktown area.
PICS: Pics to come.
OTHER: I have a vast array of parts that I am happy to package together for this car from a stock R33 RB26 engine with -5's to a built RB26 Apexi bottom end with external moroso oil pump.
Also, Step 2 HKS 2.8L bottom end prepped and ready for re-build.
Twin HKS GT3240 turbo kit
HKS GT51R KAI turbo
Single or twin 150mm drag intercoolers
Apexi head parts
3 sets of 19" Jap wheels
etc etc
Can work out a deal with any of the above for potential purchaser.
CONTACT: PM me for further details. No time wasters.
  • 4 weeks later...
Dash is in great condition, no holes or bubbles. Vents are broken but I have a complete spare dash for spares.
Drivers seat has the usual wear and tear (literally).
Will get some more pics this weekend for all those interested.
  • 1 month later...
  • 1 month later...
  • 2 months later...
This car is still registered until mid August 2014 - Just needs an engine and cooler...
Can work out a deal plus or minus parts.
Or can fit an R33 GTR engine plus cooler and get it running.
PM me to discuss options
Hi Mate
I am looking for a 32gtr or 33gtr rolling shell. I dont need any stock stuff as I am going to transfer everything off my old 32.
Let me know
Evan
  • 1 month later...
  • 4 weeks later...
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
