I'm about to have the flywheel in the CA machined (mild tune 200rwkw track car).
Can it be safely lightened at all? There seems to be a lot of conjecture about this.
Anything is a gain and it won't cost much more than having it machined. I will ask the place tomorrow, but thought some opinions couldn't hurt.
Clutch is a basic Xtreme HD Organic.
https://www.sau.com.au/forums/topic/429453-lighten-a-factory-flywheel/
Just seeing what the options are. Like any job I do, when it's all apart you're going to have a look around and think how can I improve this or what other things need replacing while I'm in there.
So it was just a case of "if" not "need".
General consensus seems to be it can be done, to a degree, but the risks go up, So I'll just get this one machined and put it back in. I can't justify $300 or so on a new lightened flywheel.
machining the cast iron flywheel is fine to resurface. But to machine till you serious Lighten..... dumb.
The outer skin of cast iron is where it's strength is. removing it seriously reduces the strength.
Bottom line is that there are plenty of true stories about lightened cast iron flywheels letting go. It's when they are put in high load / heat cycles. A clutch and flywheel breaking up a speed is a scary situation. Google this . You should have no trouble seeing the reccomendations against it.
Get a chrome molly one with the new clutch. They are like $400 or less
Nothing wrong with the Heavier style flywheels, go have a look through my build thread and see my custom version... Heavier than stock and awesome!
cast iron flywheel --lightened. Theres a few of these on youtube. You also get this with dodgy clutches too, if they let go.
Heavier flywheels that stock can make the driving /shifting easier. It also depends where the mass of the flywheel is distributed.
Removing rotational mass has significant performance benifits.
The performance benifits of a decreasing the mass are well documented.
Heavier flywheels offer drivabillity . Light weight = performance gains. Is the same for wheel weights.
What performance gains? Can you point me to any info showing this?
Mine has plenty of performance and changing to the new setup changed the car, its so much better to drive now!
Sure. I'll have look for you later. You can google the info pretty easily. Flywheels , like wheel weight are rotational mass. You can find out the physics behind that as well if you would like. It's fairly common knowledge.
The main reason passenger cars have heavier flywheels is to assist in intertia where it helps improve daily driving. Just off idle and cruising smoothness. Probably why the car feels nicer to drive.
The advantage is less mass to accelerate which tends to be more noticeable in lower gears .
IMO the greatest advantage of light flywheels is that the engine revs drop faster on the up changes particularly if you use high revs . Anyone who's drag raced with a manual syncro box knows how important this is .
The downside is such a mod makes it easier to stall when taking off because there is not the initial inertia to send down the driveline . Also especially noticeable in a cammy cranky engine .
A .
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
