Thanks leesh, hip is a little better so squat is a bit easier now
Birds, I only look in the mirror at the top or bottom of the rep, but yeah you've got a point.
I workout by myself and generally try to time my sessions so the gym is fairly empty so it will be a little difficult getting a video.
I feel fine during the rep and my movement is strict, no jerking and such, pretty sure I'm just being paranoid because that was the first time anybody has ever said anything to me about form
  • 4 weeks later...
Went to the gym yesterday after a couple weeks off, shit session and had to drop the weights back a bit.
Not surprised though considering that I have done absolutely no exercise other than a couple light jogs for the last couple weeks.
My eating and sleeping habits have been shit too.
14/10/2013
Pretty disappointing session, but better than sitting around doing nothing
Squat: 1x10 bar
1x8 @40
3x5 @60
Pullups 5 + 5 negs
Row: 1x10 bar
3x5 @40
Dips: 3,5,5 First time I've done these in probably a year, shoulder felt fine which was surprising.
A good stretch after a workout helps me avoid doms, that and a protein shake straight away with some creatine in it.
My interest in supps is purely recovery and they work for me in that regard.
Thanks, I definitely need to put in more effort I think.
Today is just active recovery, I get really bad doms after having even a short break
I'd like to share something that may prove helpfull . Doms is a normal part of life.It's different to injuries or mobility issues, which deserve some attention. Make it irrelevant to your training. Don't give it any thought, it doesn't deserve it. Accept it an move on. Paying attention to it holds you back and you may find excuses not to train or lose motivation.
Don't try to avoid doms it's a waste of time. Just train correctly and accept it may or may not occur.
In the past I would sometimes not get doms and then sometimes I'd get doms along with pain that seemed like severe tendonitis , I held to instruction and trained anyway. I learnt it's nothing to worry about.
Hopefully that helps.
Edited by rev210
Dan: I usually stretch and foam roll after a workout. I don't take any supplements, nothing against them, just a personal preference
Thanks rev, I know doms is nothing to worry about haha it was more of an off hand remark so I wasn't just posting one sentence. I definitely know the difference between doms and actual injury pain haha
I'm still doing what I had planned for today, which is a jog, some body weight exercises on whatever I find depending where I end up (park, gym, etc), stretches and mobility work.
My diet isn't great, but it's not too bad I guess. Could definitely be improved.
19/10/2013
Should be back to where I was by next session.
Squat: 1x8 Bar
1x8 @40
3x5 @65
Deadlift: 1x8 @40
1x8 @80
1x5 @100
Row: 1x8 Bar
3x5 @40
3x5 @45 More volume here because I was getting my form checked, it's all good :)
Pullups: 4..Meh
Thanks, still got alot to improve, will get there eventually.
21/10/2013
Squat: 1x8 Bar
1x8 @40
4x5 @70 Some guy commented that I have a good squat, nice and deep. So that was good to hear.
Mp: 1x8 Bar
1x8 @20
1x5 @30
1x2 @30
1x3 @30
1x2 @30 These really need more work
Row: 1x8 @30
4x5 @50
Edited by r31slpr
Pretty much repeated my last workout today.
27/10/2013
Squat: 1x8 Bar
1x8 @50
3x5 @70
Row: 1x8 @40
3x5 @50
Deadlift: 1x8 @80
1x5 @100
1x5 @110
Dips: 3x5 A little improvement here, no where near what I used to do though
Nice DL'ing and good job on the MP.
MP is a tough motion when you're getting back into it. I managed to strain a shoulder at 30kg when I started out doing it.
Take it slow and steady, Rev can also comment on some excellent assistance exercises to make sure the shoulders are healthy. His suggestions helped me fix my strain.
Thanks dan, surprisingly Mp doesn't aggravate my shoulder like other pressing does.
I think its getting better because I had to stop dips all together and now I can do them without pain, whereas before I couldn't even hold my weight on the bars without pain.
I've got no doubt my numbers will go up once I become more consistent, been missing lots of sessions due to a few reasons.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
