Squat   3x10 85kg
Bench  3x8 72.5kg
Row     3x8 72.5kg
Ohp     8,6,2,8 57.5kg ohp is hard, if I don't make all the reps by the end of the week I'll drop 10% and reset.
Rdl      3x8 85kg
Curls   3x8 20kg? I think. I've switched to oly db's and not sure of the weight, prob about 5kgs
Missed most of last week so no point putting it up
25/07/2016
Squat   3x10 87.5kg
Bench  3x8 75kg
Row     3x8 75kg
Ohp     3x8 50kg dropped around 10% due to stalling
Rdl      3x8 87.5kg
Curls   3x8 20kg db lowering the weight on these too, stop me from cheat repping it
Missed most of last week so I'm just going to write that one off.
This week had to use a commercial gym, pretty much the same as usual. Exception being, having to swap out bb rows for db rows on one day.
01/08/2016
Squat   3x10 90kg
Bench  3x8 77.5kg
Row     3x8 77.5kg
Ohp     3x8 52.5kg
Rdl      3x8 90kg
Curls   3x8 17.5kg db
03/08/2016
Squat   3x10 90kg
Bench  3x8 77.5kg
Db Row     3x8 40kg
Ohp     3x8 52.5kg
Rdl      3x8 90kg
Curls   3x8 17.5kg db
05/08/2016
Squat   3x10 90kg
Bench  3x8 77.5kg
Row     3x8 77.5kg
Ohp     3x8 52.5kg
Rdl      3x8 90kg
Curls   3x8 17.5kg db
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
