I wouldn't cut a hydro into the rear brake line, it feels like absolute crap, and then you can't foot brake and hand brake at the same time.
You have an internal drum handbrake which is very good, I'd work around that instead of cutting a hydro in.
  • 4 weeks later...
who foot brakes and handbrakes at the same time?? wank factor?? how, if your serious about drifting go for hydraulic everyone uses them because there is nomaintenance required you'll never loose that feel
Don't listen to street drifters..
so your suggesting use hydro handbrake because everyone uses them?? And no such thing ad no maintenance.
street drifters.? Huh.
As in there is a reason why everyone uses them. What maintenance can you think of besides changing brake pads?
Also don't brake pads last longer than drumpads??
Assume your heading in to a corner at over 100kph using the most common entry technique (handbrake). You notice your going way to fast but want to maintain your angle and the control of the slide. What do you do? Use the front brake while still having the handbrake engaged. Rather than I guess purposely trying spin out to avoid slamming your car in to the wall?
I use a hydraulic handbrake and still engage the front brake mid slide, if needed.
If your handbrake works, don't change it. Install a drift button. If its on its way out look at getting a brake upgrade perhaps. I run big VS commodore brakes engaged by a hydraulic handbrake in a R31 skyline. Works a treat.
^^ Handbrake isn't an entry technique!!!
That's such an 'Aussie' drifting technique - it's crap. Handbrake is a tool to use midcorner to extend your line, a tool, not a technique for initiating a drift.
Do some research about real drifting before unloading bad advice on a good forum.
Oh ok. I guess keiichi tsuchiya is wrong and you are right. I mean he is the founder and one of the best drifters in the world but of course he must be mistaken. I'll let him know for you.
Yes, it is possible to initiate using the hand brake, but it is not at all the best technique for entry.
If you follow drifting in Japan at all, or any of the current good drifters you will see handbrake entries are hardly used
The best people do not use handbrake entries. Look at Suenaga, Nishida, Streeter. They all have amazing, unique style and do not use a handbrake to initiate a drift.
This is a very recent video from Nikko, look at the technique and you will see they do not use handbrake for initiating
The amazing video of Streeter drifting Meihan
High speed on Nishi course at Ebisu
Suenaga in a near-stock 180sx
Handbrake entries are outdated, 'Aussie' and low-skill.
Oh ok. I think I understand stand now. Before you said "handbrake isn't an entry technique!!!" And now your saying it is a technique but not the best one to use? And then continue on to reference all these very experienced drifters, some even professional drivers and their amazing techniques. Which is all fine and well, however we aren't pro drifters like you. And for novice to amateur drivers like me (which, lets be honest, is a lot of us) we use basic techniques, of which the handbrake entry is the most common. You are right, it may not be the best, and I do agree with you. But it's the easiest and the most common.
It may not be relevant to the argument, however this thread is about handbrakes. Therefore a handbrake entry comment was bound to come up. Wasn't trying to start an argument. Just stating my opinion.
My mistake, I should have said handbrake is a crappy entry technique, and certainly not the most common technique.
I know you're taking a stab at me by calling me a 'pro drifter' - just to be clear I am an absolute novice, only learning.
However, I do know that relying on a handbrake for entries is a bad idea, especially when you are learning. If you learn to use a handbrake for entries you will not develop good driving skill, you will become lazy and end up coming into a corner, braking, handbrake and power out - not really drifting.
You are better off learning to control the car with your foot brake, weight transfer and throttle. I drifted for 2 years in my R31 without a handbrake at all, including my first ever drift day (which as anyone who drifts knows, is an interesting learning experience).
It is more important to learn about weight transfer and being able to brake, steer and apply the throttle correctly, handbrake is a lazy thing to use and doesn't develop your skill.
Likewise, this is an open forum and we are entitled to our opinions (although, we have gone off topic). I'm not trying to argue, I'm just interested to chat about drifting :-)
Yeah, I think we both have valid points. At the end of the day it's a personal preference on how each technique benefits your drifting based on a combination of your skills and your car. I couldn't agree more about the importance of weight transfer and how you should learn all aspects of it, rather than just relying on one technique.
In regards to the type of handbrake I use, it's a JJR hydraulic system.
http://justjap.com/store/product.php?productid=19721&cat=331&page=1
Although if you are on a budget, the ebay ones are a lot more affordable. In comparison to mine, there isnt much different in terms of reliablity and appearance. I know numerous people running the ebay ones for over 2 years now.
If a hydraulic system isn't what your after then try a drift button. Also, a much cheaper option
For an r32 skyline gtst, is the ksport one any good? Thanks! Please reply cant find good information on it.
You will be fine with stock. If you do struggle, check cable adjustment and brake shoes.
Hey dude,
Just get any hydraulic hand brake and tee it into the rear callipers.
There all the same ae! i use a D2 one, doesn't have to be a big brand
I use a 3/4 master cylinder, gives better lever feel!
In line hydro handbrake is terrible. It should a separate system or valving should be used.
Standard with decent shoes at most change lever/handle, hydro is a bit of wank looks "racey" but really not needed.
Agree with this guy
I do. It's not wank factor. Most people that use them rely way to much on them which can lead into bad technique.
If your serious about drifting, start standard and when your skill improves, then increase the performance of the car. A standard R32 handbrake is fine, if it doesn't work you've got problems you need to fix.
I would hope Handbrake isn't the most common entry technique.
Ok plenty of talk about handbrake entries as a technique, It is not. Its a great way for a beginner/firstimer to get a car sideways and learn to catch the slide and generally familiarize themselves with getting sideways and not spinning out. Its like training wheels on a bike. Mid corner (pre apex) or closing up on the lead car is about the only place its really needed. And the standard properly working line and shoes is fine save the money for some new bushes ir something
Don't know what planet someone of you guys are on.
1st you can't learn to drift of youtube, tsuchiya is a legend no disrepect but everyone is different
2nd I disagree hydrau feels like shit i've been using it for 3 years!
If need be depending on your car you could get aftermarket rear hubs which allow you to run a dual caliper setup/totally independent setups if your fussed about "that feel".
btw i wouldn't use a the foot brake and hydrau handbrake at the same time to tighten my line, that's just weird.. i use foot brake to slow down when in a slide
To the OP. As peeps have said above, if your stock handbrake is adjusted well and working good leave it at that for now.
Too many people get caught up in the "i need XYZ to be able to drift" thing.
I have drifted cars with hydro hand brakes and never liked the feel. Which Im sure can be changed by using different master cyl and such, but again, If your starting out, stock will be fine.
  • Like 1
A healthy handbrake line and good handbrake shoes (PMU or Speedtek) is all thats needed. i use speedtek shoes and they have not even thought about failing me. And when doing decent sized entrys the footbrake is needed to wash off speed and keep your angle. Id like to see somebody come hot into an entry and just use the handbrake to hold angle and wash off speed.
Edited by LTHLRB
  • Like 1
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
