I have always suggested to drill out the banjo bolt in the block (that supplies the turbo with oil) to around 2.5mm once a highflow bush core turbo is installed. After the recent failure of a highflow due to oil starvation I did a flow test of the line at idle and found there wasn't enough oil flowing, even with the line/banjo disconnected. Suspecting a blockage in the block feed I checked another car and surprisingly found the same thing, the oil was only dribbling out. I checked on my spare engine and found in the sump another oil feed line, with two more 1mm restricted banjo bolts that feed oil to the external line. So it seems there are actually 3 x 1mm restricted banjo bolts as stock. Nissan definitely thought the oil pressure was way too high for the standard ball bearing turbo...
It also explains why the oil feed is so commonly blocked. On this car I have opened up the two sump banjo bolts to 2.5mm and approximately tripled the oil flow to the turbo, hopefully enough to supply the bush core with surplus. It was a bit wet today to take pictures but I will organise some next week, it's not a difficult job other than taking the pan off.
I am not suggesting everyone should rush out and drill these two extra banjo bolts out as I have, but Hypergear and I have agreed I should do this mod to all further turbo installs, to make sure not only the holes aren't blocked, and won't easily block again, but that there is sufficient oil flow to his turbos. I am also thinking about running braided lines and a filter inside the sump to replace the hard line, as it's easier to get to than the block mounted line, and would make sure no further blockages would occur. Not sure if it's warranted yet.
Yep, Stao ships his turbo's out with a new banjo to suit the smaller thread in the CHRA. No idea why he doesn't simply tap it out, surely it's easier than cutting a banjo on the lathe... Anyway, what you did is fine Chris, just pointless if there are still two more restrictors. I would definitely suggest drilling them next service. ;)
No worries guys.
I have had a few questions on this, one being can there be drawbacks. I personally don't think it will affect oil pressure to the engine, as only a small amount still flows to the turbos, even after drilling the banjos. I would definitely like to check the difference in oil pressure between my engine and this one but I have no gauge at the moment, and it is quite hard to read pressure without the adapter plate under the oil filter. I will check it at a later date.
Another question was, why aren't other turbo's blowing up. I believe there is JUST enough oil flow to keep the turbo's spinning, any partial blockage may be enough to do damage imo. Drilling the banjos out will give the turbo some leeway with oil requirements.
Here is the oil line we are discussing...
No worries guys.
Edited by gleeson
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
