lol... I suggest you take your car somewhere else mate if that kind of advice is being given out.
There is PLENTY of info in the oil control thread. Users like r33_racer and similar have posted some pretty detailed information on the topic with full designs that are tried/proven after days on racetracks.
You would actually find that a breathing system is more important on a engine that runs E85. The fumes from E85 actually contain moisture and if your breathing systems isn't correctly set up it will mix with the oil. I don't run a drain from the back of my head but ive got a line going from the rear turbo drain back up too my catch can equalizing the crank case pressure.
  • 11 months later...
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
