RB26DETT performance parts for sale!!!
1. A pair of Garret turbo t28 ball bearing N1 done 15000kms(proven done a r34 gtr 453hp at four wheels dyno). $3000 ~~~$2700
2. A pair of Apexi turbo bolts on to gtr very new and good condition just done 200km (still have to run in the turbo)come with all the kits actuators, water line, and oil line excellent condition brand new $6900 but asking for $5000. ~~~$4300
3. A pair of r34 gtr Tomei camshafts. 260 degree and 9.15 lifts. never been use still in the box. SOLD
4. A pair of used Tomei spockets used but very new and good condition. SOLD
5. 6 Tomei injectors 600cc, very new and good condition just done 200km still have boxes. SOLD
6. HKS feul line never use, but lost all fitting. can fit injector less then 700cc 10.5m. $200
7. Veilside steering wheels used with gtr borsch kit, $250
8. Blitz intercooler will fit on r32,33,34 very good condition. $1500~~~$1300
9. Recaro Mellinium seats 2 (black) with railing very new and good condition seldom seated. will swap with standard gtr seats and cash adjustment.
10. Enkei NT03 18" X 10 with 265/35 tyres(white), will swap with any rims that fit gtrand cash adjustment.
all prices can be negotiate and be realistic as parts listed above are really in good condition and no hiding in between as all pics can be shown and will be quarentee as been shown if any unhappy cash will be given back. email me if you need any pics. all parts are located in perth
[email protected]
0433177081
nicholas
https://www.sau.com.au/forums/topic/42987-gtr-parts-for-sale~~/
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
