More questions!
What colours do the PM/PNM35s come in? So far I have seen wine red, light silver, black and white.
Is it possible to get one without the integrated stereo dash piece? I intend on just running a dual din head unit later so if I can avoid it I will.
Someone has mentioned that there is a difference in the AWD system between the NM and the PM. Is there someewhere I can read up on this? (have searched)
Is the beige interior in the majority of the PMs? Seems like 95% of them have a brown interior whether it is leather or not. Ugly!
Any other suggestions or things I should look for?
You may find this to be very informative for specs and colours:
http://history.nissan.co.jp/STAGEA/M35/0408/index.html
Someone else can speak for the AWD differences between the two models but I believe it's basically NM35 = hydraulic engagement of front shaft and PNM35 = electronic engagement.
More questions!
It's similar to the G35x system. I believe the system is called ATTESA ET-S http://en.wikipedia.org/wiki/ATTESA#ATTESA_E-TS as Hertz mentioned it has a different way of engaging.
The ones I mainly see have the same type of interior as PNmad's. Just plain cloth seats, black/grey. You should be able to score one without the integrated stereo, just gotta look for the ones with panasonic head units in them. correzza?
Edited by M35woah
What has been said about the AWD is correct. It uses an electromagnet to actuate the transfer case, rather than high pressure fluid of the previous models. Means the pumps don't fk out, and you can pull a fuse to turn it rwd.
Interiors vary, there are one beige which is horrible, the Axis had some tan/almost orange kind of leather, the other Axis a two tone black grey leather, and then there is black cloth.
Guilty!! xD, they actually half leather, suede for the pattern part and black leather with red stitching round the edges because fasts. Oh and the interiors have different options, electric and manual with/out airbags the styles differ from each other depending what option the car has (I believe this is the same for normal stagea). MANUAL FOR WINZ.
The normal Axis which has the orange/tan leather kinda grows on you when you see it in person.
Edited by M35woah
I swore I'd never buy a beige interior ever again. That will include oompa lumpa skin orange leather.
Yeah, I know yours is part suede, but didn't get it across. There is also an axis with the over fenders, while yours doesn't have them.
Options just seem to be potluck in these cars.
Axis has the over fenders and orange leather interior
Axis S (which Matt has) does not have over fenders and has the nice semi-leather interior
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
