Nice, I have mine somewhere, similarly high silicone content which didn't stress me much. I wonder if it could be from the silicone based sealant used in assembly?
I definitely prefer 4000-5000k oil changes, but I always drop it right after trackdays and heavy dyno sessions when I know it's been given a hard time. Skipping service intervals with modern engines will definitely end in tears, I have seen it many times.
  • 5 months later...
UOA number 2. 6000kms on Mobil 1 0W-40 (not Delvac 1 as stated in the report). Viscosity within spec this time. I believe this Mobil uses a grp IV basestock, and the SynPower uses grp III. Silicon ok this time.
Picture embedding is hanging my browser, so;
http://cdn.skylinesaustralia.com/forums/uploads/gallery/album_5500/gallery_15274_5500_65779.png
  • Like 1
hmm you must have been in the same queue as my check, took bloody ages to come back.
And I'm not really happy, the old place got taken over and the new reports no longer provide reference / benchmark data. I did call up and ask and they confirmed they would not do it anymore, just an overall OK or not.....they expect us to send multiple samples to show a trend over time
:down:
  • 9 months later...
Oil sample #3 looking good at 7500kms. Oil is Mobil 1 0W-40. Viscosity is good, TBN is good, just some oxidation. I have noticed the temp gauge which is usually steadfast at about 2/5s has taken a few trips up to 3/5s for no apparent reason recently, and its been very cold in Sydney. Ill take a look at the cooling system and probably run the next to 7500.
  • Like 1
  • Thanks 1
  • 10 months later...
8200kms and looking good. As usual the oil is Mobil 1 0W-40. Since TBN (indicator of additive level) is still very high, and viscosity is good, ill run the next change out to 10k. Oxidation number is high, but AFAICT its not relied on much as the test can falsely read high. Since everything else looks good, especially TBN (which at 2 is still considered ok) it makes sense to extend the OCI.
@wht510 IIRC its about $40 each for the ones i got (there are options, and the website is shitty
http://www.alsglobal.com/en/Our-Services/Industrial/Tribology/Capabilities/Oil-Analysis.aspx
EDIT: Overheating mentioned in June 15 post was due to a badly clogged up radiator.
  • Like 1
  • Thanks 1
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
