G'day guys,
Got a set of genuine keys auto headlight eyelids :) condition is alright but will need a respray to suit the new car :) Reason for sale is i have a CF set now to match my bonnet.
$80 + postage :)
cheers guys
kohbz
https://www.sau.com.au/forums/topic/430071-keys-auto-eyelids-for-sale/
