Sau Nsw Official Half Way Robertson Meet Up 15/9/13
I might be able to make it. Still waiting on that all important call...... :verymad:.... on the positive side itl be at 320-330KW when i do get it back :woot:
When are you expecting this phonecall? Before the weekend I hope. You've been waiting on this phonecall ever since I've been apart of SAU :P
It's this Sunday - Keen up ! Meeting at EPIC maccas @9am, leaving at 10am sharp. Keeners?
#@Trozzle
Sinsta32 - enable mentioning !
#@B-rice
#@THE34T
#@Manuel Kasko
#@TiTAN
#STAR33
#@Deziner
Edited by RosieR34
Dodging me m8 (luke)?
never.
I want to come.
I really do.
and depending on how things go today, I might be able to.
but, looking doubtful.
everyone who knows me on here, knows I wouldnt miss my own cruise for the world.
its not something small stopping me.
never.
I want to come.
I really do.
All good man ! I was joshing around. Would've been good to put a name to the face :P Regardless of the outcome, I hope what is holding you back is not a life changing experience.
I'm sure some of da boiz will take some photos to show for the day. I assumed you were being the lead car, is there a new lead car? I'm not sure how these things work :D
Do we know how many Sydney-siders are coming along?
Ill probably arrive sometime between 9 and 9:30, leaning more towards 9:30... But will definitely be there before 10 :P
Luke you loser! Sif not come and see me. Unless you're dying. You're not dying are you?
Keen up peeps ! need a crowd to show dem Sydney boiz how we roll in da ACT hoodz CRIBZ4LYF ! BLOODZ4LYF !
Aaaaand I'm out :laugh:
Sorry, you wrote your name in blood. So.... you're coming or we're... coming for you ! bloodz4lyf !
If these 11 hour Work days (5am to 4:30pm) don't kill me, I may end up Killing someone.
Hopefully I'll be there.
Luke Not Coming? Shell Not Coming? I'm so confused, Disappoint and Tired.
Anonymouse Coming? :ninja:
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
