All parts from a 1994 Series 1 R33 gtst 4 door I wrecked, cheap cheap!!
Many parts are pick up only unless stated otherwise so read the description carefully.
Sedan boot lid $20. Pick up only.
Rear hubs $20 each (includes uprights). Pick up only.
Front and rear sway bars $20 each. Pick up only.
Rear cradle (bare cradle) $20 each Pick up only.
Non abs brake master and booster $20 each. Can post.
Door cards- no switches included $20 each. Pick up only
Very good condition except one small blemish as shown in photo.
Rear 4 door window switches $20 each (or $40 for all three, driver's switch sold). Can post.
A pillar trims $20 pair. Pick up only.
Doors $20 each. Pick up only.
Rear bar, suit respray $20. Pick up only.
Door lock kit - doors, ignition, boot with key $50. Can post.
Steering rack $20. Pick up only.
Indicator and wiper stalks $10 each. Can post.
Steering column $20. Pick up only.
Kick panels $10 each. Can post.
Dash plastic surround (pick up only) $20
Dash pad $20 pick up only
Sun visors $10 each. Can post.
Front guard mudflaps $10 pair. Can post.
Sold/unavailable:
Motor and gearbox, headlights, airbox, clutch master, bonnet, passenger guard, under stereo pocket, engine fan, speedo cluster, lower control arms, factory stereo, centre console, stock suspension, castor rods, cat temp sensor, inner guard liners, fog lights, climate control, shifter surround, front bar and grille, AFM, ECU, drivers window switch, side mirrors, stock rims, diff, rear brakes, radiator, interior wiring loom, steering column plastics, handbrake, stock intercooler and piping, rear vision mirror, interior lights, front hubs.
How much for the plastic steering column surround thingy, pending it has no holes or blemishes? Posted to 2444 Port Macquarie?
Let me know :)
pm sent :)
is the front fender the same as for a coupe or are they different? sorry if noob question.
pretty sure they are the same
much chance you'd have a stock or a not too loud exhaust catback for a r33 sedan? also if anyone knows if the front end (guards, front bar, bonnet headlights) are the same between sedan and coupe??
nah exhaust sold already, not 100% sure on the front end parts but I only have the driver's guard anyway.
Wouldn't happen to have a speedo drive for RB25 gearbox mate?
i may have one on a stag front cut i have, need to check for ya to make sure it's in good nick
pm me if you want it and i'll check it out
  • Like 1
Hey Mate you dont have the space saver spare wheel by any chance?
Also interested in the radiator support/ boot latch with the horns attached
nah no spacesaver, bonnet latch/rad support is still available
pm me for bank details
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
