I am parting out a r32 gtst the car is NOT complied so cant be registered so I am parting it out... engine has low comp in no.1 and blows lots of smoke... car is silver and I am not selling it complete unless you want to pay $5000
bonnet - $150
type m front bar - $170
type m sideskirts - $170
rear pods - $100
seats - $150
cluster (65,000kms) - $80
speedo cable - $80
cusco strut brace - $100
front coilovers (I think hsd) - $350
rear coilovers (yet to check brand but dont match the fronts) - tbc
non abs bmc - $80
centre console with mint lid - $50
radiator - $100
fmic with alloy piping (near new) - $200
3'' catback exhaust - $200
5 bolt lsd - $150
drive shafts - $150
door cards - $80 for pair
engine crossmember - $120
steering rack - $80
gearbox - $450
bare engine with low comp in no. 1 - $150
front reo bar - $150
mint dash with vents - $250
projector headlights - $200
full manual conversion - $900
5 stud conversion - $450
front guards - $80 each
tail lights - $100
rear reo bar - $50
mirrors - $30 each
everything is for sale besides the seatbelts pm or 0420 767 957 for pics or more info
located springwood 4127
https://www.sau.com.au/forums/topic/430563-wrecking-1992-r32-gtst-complete-car/
Cheers Corin, it was the coil packs that were playing up, though I'm still interested in the afm for one of the other 32's. I've got rego and insurance next week, but if you still have it in a fortnight I'll more than likely grab it off you, but if someone else wants it, by all means sell it to them.
By the way, that exhaust I picked up from you was much less noisy than I expected, which is good :) exactly what I wanted, no drone either.
Mike.
No worries Mike I will still have an afm... good to hear that your happy with the exhaust :)
Mayby4 the front bar is sold, I still have the rest...
Edited by SIFTY32
Guest
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
