Brakes are on, Rims are on. Looks angry as f**k with the 123S's, Brake lines are on the way, Bit of a dabble in the engine bay here and there, Tidy up bits and pieces and we should be ready to fire up! Stay tuned
Not just yet, I'm trying to get most of the useless crap done at the end, Mainly I want it started and moving under its own power rather then being pushed around. Will post pics when they do go on eventually
Was supposed to be ready in May, So not sure what's going on.Havn't had the time to go in and find out. lately due to work, As far as im aware it still only needs fuel pump, fuel reg, and fluids to start..
Went in Saturday, Another 3 weeks is when work recommences on my project. So I imagine it'll only take a week to finish it all up to tuning stage, theres f**k all to be done really. So getting excited
I can't believe you're still waiting ...
I pulled out before Racewars here in Perth back in April. So he had to take on other projects in the meantime to keep work flowing through unhindered, No ones fault but my own really. Still extremely busy so it's getting around 8-10 hours on it a week from here. Better then nothing but it's getting very close.
hey mate nice build do you know if you can use a na neo cam agle sensor on the gtr 32 head.
it would be nice if you could get a good picture of the aac hoses they have used its all a bit confusing to many pipes ha.
  • 1 month later...
Couple update photos, Fair bit has been done, Mainly Radiator, Killswitch/Isolator in bay, Fuel Reg, Fan shrouding, all bits and pieces and finishing touches up , Engine bay is just about complete, So very close. Couple porn shots to keep people excited. Forgot to get a picture after we popped the new Nissan GTR Ornament plate I bought on the engine covers, It absolutely just sets the finishing touch off in the bay.
Well we had her started up for the first time, And got oil pressure etc, Everything went perfect started up first shot. Once I figure out how to get my videos up on the forums I'll chuck a short clip I got
Here have some more pics. Street tested today, Car still kicks over first shot on e85 everytime, Even after not being started for a week which is awesome. Hoping to get some run in k's on it sometime early in the new year when I'm not yolofifo'd , still working on getting the startup vid on here, But cant seem to embed a facebook video tried everything. :|
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
