Hey guys,
I recently put a heavy duty button clutch into my car last weekend, and am playing on taking it to an event this coming weekend.
I've been driving it as much as possible, but is there a quick way to bed the clutch in?
I have a 3hr drive to the track tomorrow night but it is mostly freeway. Should I consider pushing the clutch in and out occasionally as I drive? Change between more frequently 4th and 5th? Or am I going to do more harm than good?
Thanks.
https://www.sau.com.au/forums/topic/430998-quickly-bedding-in-a-new-clutch/
I would have thought a couple of days of driving in city/traffic sufficient. After a 100 or so kms again I would think all is sweet.
PS. Stay away from riding it for a short while immediately after fitted. Being a button clutch if you ride it will heat up the button easily.
Glazing can occur also.
Edited by Sinista32
In my last car (R31, RB30 engine, RB20DET box) I took my car drifting and was used the clutch as I normally would after a couple hundred KM of normal driving, no problems at all. I just did the same thing with my S14 (SR20 engine, RB25DET box) with no issues - it's all you need imo!
First clutch was an Exedy sprung brass button with an upped (1350kg) clamp load job, S14 clutch is an Exedy Sports Organic (coppermix-ish one).
im in a simlar spot my clutch is only new only done 200km maybe if that - no launches but have started to open up 2nd and 3rd clutch is still bedding in can smell it if i flog it but npc said that will happen for maybe 500km but said if i dont get enough km down the when i get to the track to warm it up and it should be fine..
dont like bedding it in special whe you can smell it but npc said its normal (was my first clutch change)
I didn't smell either of my clutches when bedding them in, I wound out 2nd gear to redline in my S14 with about 70km on the clutch too.
i got npc cushion button clutch rated 450kw.. what was your clutch and your power?
i been told it is normal so lets hope so gonna get a flogging soon hahaha
My current clutch is an Exedy Sports Organic HD - it's silver, not pink like many other Exedy clutches and has a coppermix sort of compound - like a poor man's Nismo Coppermix haha.
My power is dead stock, SR20DET.
My previous clutch was a bit of a mix, it was a 6 puck sprung brass button clutch (Exedy) but K&B Clutch Engineering in Sydney modified the pressure plate and increased the clamp load to around 1300kg. That was used with a stock RB30E, no smell either.
Both very low power applications.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
