so youre saying that everyone whith launchcontrol is a ricer and whants to get noticed ? first of all these limiters are safer for a engine you can install les revss and no fuell cutt duo to cutting the spark signal thats why unburnt fuel detonates in the elbow, but as i said it would be fine if you dont turn gain up to high which some people do because they like they bang bang indeed and yes high gain and overuse can damage but i said that my plans wherent use a high gain, so please stop bashing the limiter now and my choiche to buy one my car its my money Mkay?
My brain hurts due to lack of oxygen. Please say again in some sort of English.
End of the day, you don't need it. Post the specs of your car.
Cutting fuel is a safer fuel cut than cutting the ignition (which is why every car manufacturer does it). Cutting the fuel simply means the spark plug fires but it does nothing. Creates no heat or stress on anything. Cutting the ignition is bad for the turbo and exhaust due to the excess heat and pressure.
The only real use for this type of ignition cut is if you want to build boost while banging on the limiter in neutral, such as in a drag car.
As for whether it's genuine or not, does it really matter? From what I've read, the fakes still seem to work fine. As long as the price was reasonable then move on.
Cutting fuel is a safer fuel cut than cutting the ignition (which is why every car manufacturer does it). Cutting the fuel simply means the spark plug fires but it does nothing. Creates no heat or stress on anything. Cutting the ignition is bad for the turbo and exhaust due to the excess heat and pressure. The only real use for this type of ignition cut is if you want to build boost while banging on the limiter in neutral, such as in a drag car. As for whether it's genuine or not, does it really matter? From what I've read, the fakes still seem to work fine. As long as the price was reasonable then move on.
nicely said.
I thought cutting spark was safer as it prevented leaning out and melting pistons?
I have no experience with them but it makes sense. Could overspin the turbo if the fuel ignites in the turbo though.
If there's no fuel there'll be no ignition (as in no bang), so no risk or pinging or higher cylinder temps
Spot on. No fuel = no bang = no heat. And even if you had the tiniest amount of residual fuel vapor in there, it would actually be so lean that that it wouldn't actually cause much heat, if it was even enough to ignite in the first place. You get to a point where leaning out doesn't get hotter, and temps start to drop. Think about it, if you have a big fire it heats up a big area, but lighting a match in the same area won't do squat.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
