Mugabetown - Whoretownin' At It's Worst.
man I am glad I did my Ps when I did. I had my blue rig while still on my Ps
Me too. my skyline is the first car i ever owned. I was 18 or 19 when i got it but ti was still the first car i owned and i had 2 years of my p's to go
Commo? One day these hellaflush idiotz will realise stupid amounts of csmber is just retarded.
Big offset with lots of camber and stretched tires looks cool if done right and it's clean... On a commo hell no
Just finished my first approval since the new 'green tape reduction' legislation came in, my mind hurts. Reduction my ass that was the most frustrating work experience I have had for years
And you never saw that coming? They'll defect cars on trailors as well. Why causs they want us to go to tracks to play but then know where we congregate so they see easy dollar signs.
can they defect a car on a trailer there? i know here they cant touch a car on a trailer, they can defect the trailer and the tow car, but not the car on the trailer.
  • Like 1
What if the car on the trailer is a road registered car?
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
