Mugabetown - Whoretownin' At It's Worst.
Just went out to the shed to get the skyline out to wash it and take it for a drive and the battery is flat. The trickle charger sh*t itself sometime over the past 3 weeks
next time take the battery out!
Disagree. Dirt, dirt cheap, gets you anywhere, not the worst on fuel.
LOL! worst daily choice ever is an old Falcon
For a carton of xxxx and a bottle of scotch can't really go wrong, ac is cold and it uses half as much fuel as the abomination, also means I can start bying parts
Only because the abomination is a thirsty POS.
  • Like 1
Question... who has had a screamer pipe before? Ive always been against it due to driving my car a lot and it would be annoying. Now i wont be driving my car anywhere near as much im contemplating getting one for something different. As far as im aware there is no increase in performance having one..
i have had one, they are loud and if you have a tiny turbo/internal gate, just no.
in that example, sure.
when the dump pipe is fabricated get them to make a section that can unbolt so you can seal up the exhaust and have it as a screamer but also gives you the option to plumb it back with relative ease.
some people love them forever, some people like them for a bit and then just want it to shut up.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
