Mugabetown - Whoretownin' At It's Worst.
Just went out to the shed to get the skyline out to wash it and take it for a drive and the battery is flat. The trickle charger sh*t itself sometime over the past 3 weeks
next time take the battery out!
Disagree. Dirt, dirt cheap, gets you anywhere, not the worst on fuel.
LOL! worst daily choice ever is an old Falcon
For a carton of xxxx and a bottle of scotch can't really go wrong, ac is cold and it uses half as much fuel as the abomination, also means I can start bying parts
Only because the abomination is a thirsty POS.
  • Like 1
Question... who has had a screamer pipe before? Ive always been against it due to driving my car a lot and it would be annoying. Now i wont be driving my car anywhere near as much im contemplating getting one for something different. As far as im aware there is no increase in performance having one..
i have had one, they are loud and if you have a tiny turbo/internal gate, just no.
in that example, sure.
when the dump pipe is fabricated get them to make a section that can unbolt so you can seal up the exhaust and have it as a screamer but also gives you the option to plumb it back with relative ease.
some people love them forever, some people like them for a bit and then just want it to shut up.
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
    • Nice, that's not laggy swtching between functions at all. Could it be less laggy than the factory one below? 😋
