Mugabetown - Whoretownin' At It's Worst.
That's because IT workers are like assholes... I mean opinions... Everyone has one...
This is exactly why I work in a very specific area of IT, one that keeps the rest of it at arms length.
And most IT workers are assholes...egotistical assholes.
Yep, I'm an asshole, it's why I'm in IT... But not so much technical side, LOL
What do you do in IT specifically Clint?
I work in Control system security, I am responsible for the supply and support of the control systems, the Wan's and Lan's they operate on and the security of the off net network for a large utility.
So.... Zac and I got stalked today. And not by any random person. Zacs nan. She had a stake out. Just chilling in her car outside zacs work waiting for me to go see him. Wtf!! Messed up
lol Ninja Nana.
Sounds... Fun... :P
Get me a job with you? I feel the need... The need for acceleration (Change for those not getting the relationship) :P
Everyone works in IT now days the Industry is such a broad spectrum of jobs and people.
They specialise in particular areas but I don't need to/want to/not allowed to know what they actually do - All I know is they are extremely good at what they do and they have both being flown around to different countries for conferences, training etc... Good for me, I get souvenirs and they get frequent flyer points to fly me around Aus when needed yayyyy!
Sounds... Fun... :P
hahaha take a number and get in line, Heaps of people want in on what I do...There is a serious lineup to get into my field.
What IT experience do you have Matt?
None. Oh you said Matt not tony. :P
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
