Mugabetown - Whoretownin' At It's Worst.
thanks bro. that means a lot. I was really lookin forward to getting my car back. Finally seeing it on the Dyno last week was really exciting. Now it just feels Im getting shatterred all the time.
if you need it no probs man as i said my car is of the road and my business is main priority now so you can use if you need
Anyone know how to remove gel nail polish? It's the shit that is cured under the UV lights...
Soak cotton wool in nail polish remover and press onto the finger nail and sticky tape it on there for an 1/2 and hour, take off tape and wool and run with a Brillo pad or semi abrasive cloth.
Hand buff nails and apply French tips cause they look cute and classy and easy to remove ;)
nick join the rockstar social club mate. look for a skylinesaustralia crew.... its for gta.
let me just check in my handbag...
At least you have a handbag, I don't!
Winning! Usually stuff just peels off my nails within a few days, 3 weeks later it's still stuck on and shitting me to the max!!!
p.s. Thanks!
I actually know the answer to this, soak in acetone for about half an hour and they fall right off, Anna does this all the time!
Unless it is pink and sparkly I am seriously one of the shittest girls ever lol...
...the cock, it may have been in and around your mouth hole
Ah ok man my home Internet is down ATM and will be for like a month :(
Refer to above it may speed the repair up
I found an old bottle of ma blaurk nail poilish from back in the day a couple weeks back, made me ltm
Need to remove this from your brain with an intense marathon of beer, cars, Porn and football.
Anna is a bit the same, though due to her career knows lots of beauty/makeup stuff, aside from that, loves hello kitty, also rebuilds engines lol
It cant be removed, half of my house is a makeup salon, Anna works at a makeup supplier, brides come to our house to discuss makeup, half of Annas friends are in the business. ITs here to stay, but it makes Anna happy and makes us money so I am all good
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
