Mugabetown - Whoretownin' At It's Worst.
the main difference is the map sensor.
newer gen vipec runs a 3 bar map sensor vs links 2.5 bar.
that was it for the differences afaik, and if you arent looking to run more than 30 psi thats all good.
From the web site it also looks like the Vipec has knock control built in where as the Link needs the knockblock add on?
And isnt it 20psi for the link? Because you have to take away 1 bar for the atmosphere?
I recent acquired a link cheap so I didnt research as much as usual so have some questions from someone who has used them!
as i said, 3 bar absolute vs 2.5 bar absolute (so take 1 bar away from both to get positive pressure)
Hatlech doesnt have knock control does it?
What model did you get?
I see, now I am on the same page
sending you to swim with Sharks :dry: eh!
kinda tells me they wanna get rida ya :devil:
Lol nah they like me too much, I deal with the people they don't need to lol
Swimming with sharks is like getting something out of the bottom draw in from of a seedy old man.
You feel safe, until you leave something exposed
This is very true, I'll either get eaten or speared by a stingray haha
they are a nice ecu and can do lots of nice extras, flat shifting and igition retard launch control provide pops bangs and stationary flutters/bov
ie, sitting at the lights clutch in, revs up, turbo spools, left off throttle. aww yea, 20 psi sitting still.
also they sound awesome with the antilag on.
whos car is this?
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
    • Have a chat with the tuner, you'd want to drive the car straight there.
