Mugabetown - Whoretownin' At It's Worst.
Plates have changed since last time it happend just FYI
Getting to seem like it, I have a perfectly clean driving record don't even have any parking fines even my dad and some of his friends think it's ridiculous and they were cops when I was growing up.
Your car is pink right? It would stand out a lot. I expect this pulling over thing will be very regular
Where did you go!?
There was a second universe the exact same as ours but it was different. And I got stuck in the second earth. Couldn't get back, and it affected our earth, causing flooding and rain.
Trippy dream right there. I have a new novel idea now :D yay
They go through phases, earlier this year pulled over 10 times in 9 weeks, then nothing since about April and now again 3 times this week. Before that maybe 5 times whilst I have had my licence (including on P plates in Pinky) and it has always been pink in the 7 years I have owned it. I used to get pulled over more on my scooter than in the car.
Yeah, and people think I am a tripper watching Charlie the Unicorn lol....
But seriousl wtf did you watch before you went to sleep last night haha!
I watched wonderland. This is the only dream I've ever finished awake. It envolved sau people to :/ that makes it weird haha
LOL! Awkward...
Last dream I had that I remember was meeting webber, at a beach... It was after watching an F1 race and the same night Zane had a dream he met webber but at the track lol which is why I asked what you watched before it haha
already a film....
Does This only happen when you watch Dr Who before bedtime :)
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
