Mugabetown - Whoretownin' At It's Worst.
Sif be at drinks when you could do 12 hour days all weekend
12 hour days suck balls - I feel for you, I am lucky if I get one day off per week sometimes 2 per f/n let alone 28 days on...
Where abouts do you work?
28 on is about the worst roster ive heard. 14/6 is the most id do f**k anything else.
12 hour days are absolute standard in construction though so meh harden up Pete :-P
Thank f**k this week is over though, whatever could go wrong did go wrong this week. So shit.
Bring on long weekend and North Straddy awww yeah
I'm only doing 21 days this swing and back to 14 days next swing, don't feel bad for me, heck 1 day off a week is worse in my book, you just have the luxury of that day being a weekend, and things like long weekends, and being able to go to things/events after work etc.
Moaning is just the only thing that keeps me going through the days :yucky:
MCJV does a 28 day roster for some of its staff though... I can conclusively say, screw that!
A few more photos
{style_image_url}/attachicon.gif ImageUploadedBySAU Community1380884143.715177.jpg
{style_image_url}/attachicon.gif ImageUploadedBySAU Community1380884158.767778.jpg
This makes me yet and difficult to go to sleep.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
