Mugabetown - Whoretownin' At It's Worst.
Haha go to buy some hmmm... Do you have any more of this out back I need to fill a bath with it...
Sales person... Ahhhh WTF...
Noooooo.... sales person: We'll arrange for a personal guided tour of the factory for you and complimentary mixing vat pool pass rofl
True they go a long way for a sale lol
Surprisingly there is another brand of that stuff that does get sold by the 44gallon drum.
Known in industry as just "Barrier Cream"
The electricians at my old job introduced me to it, I also worked with a bunch of fitters. The fitters called the electricians poofs for using "hand cream"...
Yeah, one of the fitters finally tried it... Now the fitters are also being a bunch of poofs and using hand cream... LOL Stuff is magic for protecting your hands from grease and grime. Should get my step dad to get me some for while I'm working on cars... Although, I've also been abused into wearing gloves so I dont cut myself as much... LOL
Barrier cream - that takes me back. This stuff above is supposed to be all natural. I use mainly vinyl gloves these days KBS have some awesome ones and so do Hercules (Nitrile). Anytime hot engine bay Mechanix gloves straight on, so sick of getting burnt when adjusting/checking
I don't care what anyone says, anything that is "man made" is still natural.
It's what happens naturally when you compress/heat/cool/aerate/mix certain chemicals. These things just happen... Just because we give them the ability to happen doesn't mean it's not natural.
Just like electricity flowing through a resistor in a vacuum emits light... This is natural... Nature and physics allow it to happen :P
By natural I mean lacking carcinogenic chemicals, but yes they exist therefore they are natural lol
but there is a distinct difference between something natural and artificial Marie
Immy out hours ago. Every time she sees me on computer, she tries to play pokies with the keyboard. go daycare you good thing :)
i was referring to LukeGTR. But my daughters were lights out an hour ago now
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
