Mugabetown - Whoretownin' At It's Worst.
Fk financial advice most people would say I am a terrible person to discuss financial advise with but the way I see it I am a problem solver, something goes wrong I find a way to fix it, same with money. When shit hit the fan with my douche of an ex I had near on 65k of debt for shit we had that he kept (inc. 2 cars and a dirtbike plus c/card crap) 4 years later its down to 15 plus I have paid off an additional 15k cash in education expenses over the last two years on top of my hecs - Then people wonder why I work all the time and have no money. Debt sucks and the only debt I look forward to is a house, I learnt the hard way! But knowing I can pay all my shit plus save for a wedding, pay rent, groceries for two and all the house bills whilst the other half hordes money for a mortgage is well worth the amount I work! How do I do it? I am insanely organised to the point that I often freak myself out that I have forgot something but it is just that I am that organised...
However if I don't give a shit I am not organised at all...
Disciplined :)
Haha not the right word for me, I problem solve - Really want those shoes really can't afford them, wing it so I work more that week to get them...
That's even more disciplined. In management terms they call that Locke's goal setting theory. Essentially you set waypoints to getting things you want to achieve. They have another acronym too called SMART
Specific - there is a precise and clear statement of intended outcome.
Measurable - there are clear indicators (quantitative or qualitative) of whether goal has been achieved.
Achievable - The goal is achievable, within available resources and environmental constraints, and is compatible with other goals that have been set.
Relevant - the goal is aligned with broader goals, values and priorities, which provide a rationale for the goal.
Time-bound - The goal includes a statement of precisely when it is to be achieved.
Winning Mel :)
Mel, if you've managed to affectively clear 65K (50 in debt 15 in education) in 2 years, I wouldnt say that you're bad with money... I'd say you've got it quite well managed at the moment.
Oh an Tim... Do you happen to have a spare R33 GTST S2 bonnet you'd part with?
I didn't get one with 2nd car - had to negotiate that out, as I had Titans. I can get you one pretty cheaply though, or a GTR one if you'd like they are significantly lighter. PM me for details.
No all pretty good
Just a little bit of carbon build up, looks like it was maintained well
Ok so question
If Kathryn gets this na 33
Should I take the cams and injectors from the rb25 I just picked up and put them in hers or are the cams the same
I Know the inj's are a good upgrade
No all pretty good
Ok so question
I'm not sure about their compatibility, as I normally upgrade with aftermarket stuff. I am guessing, but there may be a difference in the engines compression ratio (piston tops)and there would most likely be stronger valve springs in the turbo motor, also the valve seats might be different. inj shouldn't be a problem. According to Wicki the bore and stroke is the same and the cams are the same duration and lift between the motors, accordingly no benefit from cam swap. http://en.wikipedia.org/wiki/Nissan_RB_engine
Also, sounds like you sourced a really good RB30 engine. :)
I wouldn't swap cams.
NA and turbo engines run a different profile for a reason.
Injectors, will it need extra fuel? What're you going to do to tune it? What mods to require more fuel?
Tim PM incoming on 2 different topics
Ok guys so if all goes well on Saturday providing Ben can make it and I get his 31, my goal is to have it on the road for charity cruise the only bad thing that will hold me from having this happen is being broke as a bum
If you get the na, don't go sticking turbo bits in while na.
Turbo cams and na cams have different profiles because they benefit from the cams have more or less overlap depending on desired application.
If you get any mods for it keep them basic as they arent worth much when sold and will cost significantly more than just buying a turbo one to begin with
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
