Mugabetown - Whoretownin' At It's Worst.
Greg, I called that dude today about white rb30 - he sounded fully sic and tells me it's not modded, but genuine Tomei rb30 cam, valves, springs and retainers.
ha! Even more lols.....
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
